Thread Tools Search this Thread Rating: Thread Rating: 89 votes, 5.00 average. Display Modes
Old 08-19-2013, 02:49 PM   #41
dedekind
My Ride: 2001 330ci
Originally Posted by Sansho View Post
It doesn't hurt to check realoem.com on part numbers. The oil filter is 11427512300, as you indicated.
yeah, this is just in case some other noob like me reads this and goes directly to the dealer with the part # posted, not even telling them the model/year of the car
dedekind is offline   Reply With Quote
Old 08-21-2013, 10:53 AM   #42
Hogan773
My Ride: 2002 325xi
You wont make that mistake again
Gotta be careful on this forum since there are many DIY proclamations but there are a lot of slightly different models on here.....and everyone is talking about THEIR MODEL obviously
FWIW I got Mann filters from Amazon and they were like $6 bucks each. Next time you have an order for Amazon, just pick up a couple with free shipping and throw them on your shelf. The Manns are 100% the same as the BMW and get great reviews.
Hogan773 is offline   Reply With Quote
Old 08-24-2013, 11:26 PM   #43
kdavidson
My Ride: 1997 328ic
Walmart usually has the Fram brand for about the same price if you need one in a rush. They also include the O-rings and crush washer.
kdavidson is offline   Reply With Quote
Old 08-25-2013, 03:59 PM   #44
2_Fast_2_Stop
My Ride: 325ci
Good writeup. For mine, after step #2 I had to push the left button 3 times in rapid succession for it to reset the service light. Now it says 25,000 Service. BMW really recommends this duration? I'm sure I'll do mine every 5k like everything else I own
2004 325ci, 2006 Dodge Charger SRT8, 1990 Nissan 300zx tt, 2006 Chrysler 300
2_Fast_2_Stop is offline   Reply With Quote
Old 09-07-2013, 12:12 PM   #45
slimg00dy
My Ride: E46 325i
Finally found it.
Ignore this post
slimg00dy is offline   Reply With Quote
Old 10-10-2013, 02:55 PM   #46
PosingOwl
My Ride: 2004 325xi
Re: BMW E46 3-Series DIY: Oil Change
Nvm found it
Sent from my SPH-D710BST using BimmerApp mobile app
PosingOwl is offline   Reply With Quote
Old 10-10-2013, 03:29 PM   #47
jayb328i
My Ride: E46 2000 328i
Since I always change oil from the top using an oil pump, I would assume it is the standard direction to loosen, but I am not going to comment since I have not done it using the plug. Why not get a oil pump--much easier and safer, no need to get dirty under the car, not need to open the wrong plug.
jayb328i is offline   Reply With Quote
Old 10-10-2013, 08:24 PM   #48
PosingOwl
My Ride: 2004 325xi
I thought about that and I might buy one now.... I accidentally loosened the transfer case lug and some fluid got out. Took it to a shop to check how much and they said there was none in it
Now I need to find a transfer case fluid around here. What happenes if you drive on it like that. How much can you drive. Went to 3 stores and they all told me I had to call bmw to get it.
Old 11-03-2013, 05:30 PM   #49
JTFastDriver
My Ride: 05 325i Sport Sedan
Question Help!
Great article. But I just realized that I did NOT include the crush washer when I replaced the drain bolt whe I did the oil change YESTERDAY. I only have the brass washer on the bolt. Will I be ok between changes OR do I NEED TO get the crus washer on there???
JTFastDriver is offline   Reply With Quote
Old 11-03-2013, 05:35 PM   #50
jayb328i
There is a reason why BMW included a crash washer to be inserted, If it was not important they would not have provided it.
If it was my car, I would not risk driving, knowing that the oil drain plug is not secured properly, and if it leaks the engine will fail.
Old 11-09-2013, 09:18 PM   #51
DEADF15H
My Ride: 2001 325i Auto
Just a couple of suggestions. There is a small O-Ring at the bottom of the stem on your oil filter cap (shown in your picture), on my 2001 325i there are two(2). The Bentley manual calls for changing it(them) every time you change your oil. I am an intermittent DIYer, if I have time to change my own oil, I do it, if not,I pay to have it done. I am sure my O-Rings haven't been changed during my last 4 oil changes, as I paid someone else to do it and those tiny @#%****S are $7.51 each at the dealer. I bought them and changed my oil today, they don't come in the filter kit, but they should, only the large O-ring was included in mine. I haven't checked BavAuto or elsewhere yet, but I will. The old ones on mine were quite brittle and discolored.
I change my oil from underneath the car. I use a magnetic oil plug, checking for metal shavings on the plug, or gunk build up in the bottom of a pan is just a precautionary measure, it's overkill, until you actually do find shavings and nip a problem in the bud before catastrophic engine failure. I will, and have used a Motive pump, I just don't make a habit of it. I also like looking around underneath to make sure everything looks right. I did find a worn out rubber bushing on the right control arm this afternoon.
It's a lot cheaper on these cars to catch an issue early, and some of them can only be found from underneath. My car is 13 years old, it wasn't designed to last this long, plastic and rubber parts get get brittle and crack. Replacing them before they blow out will save money in the long run.
DEADF15H is offline   Reply With Quote
Old 11-12-2013, 06:43 PM   #52
EthirD
My Ride: '02 325iT, '07 X5
Originally Posted by 123Shift View Post
I can't see how the viscosity really makes that much of a difference, 5W-30 falls within the range of 0W-40. 0-40 just gives you a greater range of weights. But I guess it can't hurt to switch. 5W-30 was just convenient because they sell that weight at my local Costco. Thanks Sansho.
The viscosity doesn't make the difference - M1 0W-40 uses a superior base stock when compared to the other M1 weights sold in the USA. If they were all created from equivalent base stocks, then they would all be approved, but in this case, just the one weight is made from the right stuff.
wagon devotee
BMW CCA Member #480924
EthirD is offline   Reply With Quote
Old 11-16-2013, 01:28 AM   #53
zxxzvzxcbxzcbzxc
Banned User
Thank you, I'm going to bookmark this DIY.
zxxzvzxcbxzcbzxc is offline   Reply With Quote
Old 05-31-2014, 10:52 AM   #54
niniGr8
My Ride: 2003 325i
Great post joeycannoli, I did oil change for the first time in my 2003 E46 325i. The tools list was very helpful along with the picture.
The only difference in my model was I do not have to open the belly pan and was able to reach the drain plug via a opening behind the belly pan.
2007 E60 530i Sports - gone
2003 E46 325i Sports
niniGr8 is offline   Reply With Quote
Old 05-31-2014, 10:56 AM   #55
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Use this 1/2 the time - no mess
Bimmer4Lyfe is offline   Reply With Quote
Old 07-15-2014, 06:55 PM   #56
waclosh
My Ride: 2003 325ci
Wink Skipped the first thing!
There is still one more thing missing in the writeup. You really want to get rid of all the debris and dirt, that has accumulated in your oil pan and elsewhere inside the oil system, right?
Get everything ready for the oil change, but before changing the oil, follow these steps:
1) get the car started, go for at least a 7 mile ride
2) get it warmed up and then give it some...
Driving the car a bit harder (ringing out the gears a little) will disperse whatever has sedimented inside your oil system/engine.
Immediately after returning to your garage with the warmed-up engine, approach the first steps of draining the oil. This will ensure that the warm oil, with all the metal pieces, residue and dirt perfectly dispersed in it, will flow out of your engine leaving it pretty damn clean for the new oil.
Just be careful not to get burned when removing the drain plug. Good pair of doubled rubber gloves is advisable.
waclosh is offline   Reply With Quote
Old 07-17-2014, 02:48 PM   #57
simplysic
My Ride: 2003 325i
`123 q
simplysic is offline   Reply With Quote
Old 10-08-2014, 06:41 PM   #58
joeycannoli
My Ride: 911
***All, the original site hosting the images was removed. The pictures along with the full DIY can now be found below***
BMW E46 3-Series Oil Change DIY
BMW 325xi
Porsche 996 GT3
Joey Cuccaro
joeycannoli is offline   Reply With Quote
Old 12-19-2014, 09:49 AM   #59
desir
My Ride: 2003 325i
Originally Posted by wjb21ndtown View Post
FWIW... I wouldn't put castrol in my lawn mower. I took an engine into my machine shop (BBC) for a performance upgrade. My machinist called me and stated verbatim "You use Castrol, don't you?," and I replied, "yea, Castrol GTX." He said to never use that oil on anything. I asked him why and he said that he'll set my oil pan aside until I get there. It was nothing but sludge, and he had to use a scraper to get it out, and I change my oil religiously. He showed me an oil pan with Valvoline and showed me what it was supposed to look like... Filmy, but washed out in the parts washer easily. He said it really didn't matter what other company oil I use (Penn, Valvoline, etc.), and that it's always Castrol that looks like that. Take it for what its worth, but I've seen it first hand and he had no bias in the situation, and wasn't pushing any one product, just cautioning against that one.
Now I use Mobile 1 synthetic in everything.
Now for the real reason for my post...
This DIY has a typo... In the list of tools it says to use a 36 mm socket, but in the description of what to do and when it says "now grab your huge 35 mm socket" to take off the oil filter cap, which is it?
U mean u put some normal castrol? Like a blend or something in ur BMW
I dont see why castrol FULL SYNTEC would make sludge.
desir is offline   Reply With Quote
Old 12-23-2014, 10:20 AM   #60
Manny04
My Ride: BMW E46 325CI
10w-30 FTW
(112k, sub tropical climate)
325CI
Manny04 is offline   Reply With Quote
