Australia
Old 11-15-2011, 08:45 AM   #1
willy3000
My Ride: BMW 2001 E46 320ci
Starter motor mounting holes help!!!
According to RealOEM.com the right starter motor for my car is part no 12411740379 which bolts holes look like this
But it would be impossible to install because the holes that the bolt goes into is NOT threaded, the old ones looks like this
I need those threaded holes so the bolt can fix onto it. But even BMW recommended me the un-threaded hole for the starter. Is there so additional bracket I need to install the starter motor?
willy3000 is offline   Reply With Quote
Old 11-15-2011, 04:13 PM   #2
bobz
My Ride: 0 BMW's
Maybe because the block or the bell housing is threaded....
Have you taken the old starter motor out????
BobZ
"Little knowledge is Very Dangerous"
bobz is offline   Reply With Quote
Old 11-15-2011, 05:04 PM   #3
DamoBMW
My Ride: '02 325Ci M-Sport
Oh boy, the starter motor is not fun to take out. To unscrew those 2 torx bolts I had to use about 6 adapters for my ratchet. The hardest part is getting the torx bit to actually go into the bolt head as there is very little room! You have to reach up there and guide it on (easier with smaller hands), then while someone else unscrews it I held everything in place to make sure the torx bit doesn't come off the bolt head.
'02 BMW 325Ci 5MT M-Sport Individual Stratus Grey
DamoBMW is offline   Reply With Quote
Old 11-15-2011, 05:07 PM   #4
DamoBMW
Originally Posted by willy3000 View Post
I need those grooves so the bolt can fix onto it. But even BMW recommended me the groove-less hold starter. Is there so additional bracket I need to install the starter motor?
There is no additional bracket. The bolts just screw into the block like bobz said.
Old 11-15-2011, 08:40 PM   #5
willy3000
damn... that means i bought the wrong part..
Old 11-15-2011, 10:34 PM   #6
bobz
My Ride: 0 BMW's
Yes or No
BobZ
Old 11-16-2011, 12:11 AM   #7
willy3000
Yes or No
BobZ
No,
But im pretty sure the old one has threads on the hole.
Old 11-16-2011, 01:55 AM   #8
bobz
My Ride: 0 BMW's
the part number you supplied has the bolts going through the casting and onto the starter motor, did you get a new starter already delivered?
BobZ
Old 11-16-2011, 02:27 AM   #9
willy3000
BobZ
yep, got it last week. i think it wont be able to mount cause the hole on the starter has no threads....
Old 11-16-2011, 02:36 AM   #10
shannon1
shannon1's Avatar
My Ride: 2001, 318i
You may have to bite the bullet and remove your current fitted starter motor and really check it out and look for any part numbers.
I think our cars all came with Bosch starter motors so you may find a Bosch p/n instead of the BMW p/n but you should be able to find info on the net to sort that out.
Shannon.
shannon1 is offline   Reply With Quote
Old 11-16-2011, 06:10 AM   #11
bobz
My Ride: 0 BMW's
So the starter motor you got has it got threaded holes?
BobZ
Old 11-16-2011, 06:43 AM   #12
willy3000
BobZ
the new one no, the old one yes. im going to take it out tomorrow but im pretty sure the old one has threads.
Old 11-16-2011, 07:03 AM   #13
DamoBMW
I have a feeling the old one in your car doesn't have threaded holes.
We'll see who is right soon .
Old 11-16-2011, 07:22 AM   #14
willy3000
I hope your right, cause im 100% sure I bought the right part.
checked it through realoem.com lol
Old 11-16-2011, 07:41 AM   #15
bobz
My Ride: 0 BMW's
When you had a look at the realOEM picture the right one has the bolts going from the front of the car to the rear and the bolts are threaded to the starter motor....,
BobZ
Old 11-16-2011, 07:41 AM   #16
bobz
My Ride: 0 BMW's
BobZ
Old 11-16-2011, 07:50 AM   #17
N4NOOK
My Ride: 323ci
my old cars starter wasn't threaded as bobz is saying so i think you'll be safe
N4NOOK is offline   Reply With Quote
Old 11-16-2011, 05:24 PM   #18
willy3000
i heard they changed the size aswell, the old one is apparently smaller, whilst the new ones are a bit larger.
