Tranny any DIff Oil - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-15-2011, 06:16 PM   #1
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Tranny any DIff Oil
What tranny and diff oil are you guys running? Any suggestions? BTW, I am running the OS Giken Diff.
MSpired is offline   Reply With Quote
Old 11-15-2011, 06:23 PM   #2
SweTurbo
Big Pimpin'
My Ride: 323i -98
Tranny 1quart Redline MTL-90 and filling up with D4 ATF
Diff Castrol Syntrax Limited Slip 75w-140
I like redline and castrol and wouldn't put anything else in those 2 parts , engine though i vary..
Old 11-15-2011, 06:50 PM   #3
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I'll never touch another redline product...general consensus is that the redline oils are good initially but they quickly degrade. IMO put the OEM BMW recommended gear oil in the transmission and the OS Giken Recommended oil in the rear.
Old 11-15-2011, 07:28 PM   #4
SweTurbo
Big Pimpin'
My Ride: 323i -98
Where's this general cons from ?
Been using redline tranny oil since 2008 and still feelt like new when i tore down the tranny earlier this year. havent done any chemical tests but it looked(slighlt more brown) and smelled(urgh) just like it did going in.
Old 11-15-2011, 07:32 PM   #5
MSpired
What about Royal Purple products?
Old 11-15-2011, 08:07 PM   #6
Steven747
My Ride: 05 330ci
I've only heard that royal purple disintegrates early. i use redline in my diff and tranny and its been in there for almost a year and i have only had success with it. i drained and inspected at about 20k miles and it looked red like it was going in but i saw a lot of little flakes here and there which I'm sure it cleaned out the tranny of any parts. i put new fluid in and checked it very recently and saw no flakes so i believe it cleaned out my tranny good...
unfortunetly i didn't notice my tranny getting any smoother but it certanetly didn't change from having the old oem fluid in it just cleaned it out..
btw i used mtl
Old 11-16-2011, 02:12 PM   #7
Minnoe07
My Ride: 2004 BMW 330Ci
Transmission fluid is Royal Purple MTF. Royal purple does disintegrates easily. I wouldn't recommend it. I have to change it every 15,000 miles to keep it smooth. I will go with Redline next probably.
For your OS Giken differential, you NEED to use the OS Giken approved fluid in order to maintain performance, reliability and warranty if you still have one. It is a 80w-250. You can get it at Turner Motorsports for about $50. You will need 2 quarts, although you will barely use the second quart.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 11-16-2011, 06:53 PM   #8
MSpired
Ordered OS Giken Diff oil and Redline ATF, thanks guys
Old 11-16-2011, 06:57 PM   #9
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
How long have you had an OS Giken?
Old 11-16-2011, 06:58 PM   #10
MSpired
IDK, I ordered it a while ago but actually put it in the car like 3 months ago, why?
Old 11-16-2011, 07:08 PM   #11
MarcusLSB
Curious how often you were changing the fluid in it. I've had mine in the car for probably 2000-2500 miles.
Old 11-16-2011, 08:30 PM   #12
funkboy316
My Ride: 2003 M3 vert
there is an initial fluid change on the giken...dont remember the mileage(1000 pops in my head but im not 100%), but i remember HPF telling me once driven for X amount of miles change out the fluid, i think after that its every 10-15k.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 11-18-2011, 02:50 PM   #13
Minnoe07
My vendor recommended break in fluid for about 500 miles, and after that he specified that I should just come in and get the oil analyzed to see if it needed changing due to the fact that it was expensive oil. Back then, it was $100 a quart. Now it is $50 so I might just change it myself soon. I'm around 15,000 on this set.
Old 11-18-2011, 03:12 PM   #14
Estoril-E46
My Ride: M3
NO, do not use any diff oil made for limited slip differentials (have FMs) and do not use any friction modifiers for the OSgiken.
edit: scratch that, misunderstood osgiken. They said do not use any FM but meant do not use ADDITIONAL modifiers with oil already made for lsd (with modifiers) (obviously). Also said oil that is not specifically for LSDs is fine as well.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 11-19-2011, 12:31 AM   #15
rosiebmw
My Ride: '03 325i
Just had my tranny changed at 70K with Castrol Import Multi-Vehicle Transmission Oil. Required just over 7 qtrs @ $5.89/qtr at AutoZone. Will change it again every 30K. http://www.castrol.com/castrol/secti...tentId=7028224
rosiebmw is offline   Reply With Quote
Old 11-19-2011, 12:57 AM   #16
GotE46M3
My Ride: NA
Changed my Diff and Trans with Royal Purple. Since I have an SMG its absolutely amazing the difference the trans makes after a fresh oil change.
GotE46M3 is offline   Reply With Quote
Old 11-20-2011, 01:19 AM   #17
Bdave
My Ride: M3 HPF Stage 3
Expound (present and explain a theory or idea systematically and in detail) please.
Also, Why RP instead of Redline which seems to be a much more popular choice?
What stage clutch do you have? Any chatter before or after SMG tranny oil change?
Bdave is offline   Reply With Quote
Old 11-20-2011, 01:27 AM   #18
MarcusLSB
Old 11-20-2011, 02:13 AM   #19
Bdave
Have to eje-kate yins some how in the Kings engish
Old 06-14-2013, 10:36 PM   #20
Lunatic
My Ride: 2007 335i
Hey guys I have a buddy that is new to bmw....hi first is a vert m3 with smg.......im going to help him change his engine, and tranny oil....ik how to change the engine oil its pretty str8 fwd, but I have no clue on smg....ive looked around here and nothing I even used the search bar.....help!!
Lunatic is offline   Reply With Quote
