Old 06-15-2013, 03:41 AM   #21
leletyM3
My Ride: 05 M3
I just use BMW OEM
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser
leletyM3 is offline   Reply With Quote
Old 06-15-2013, 06:49 AM   #22
MisterM
My Ride: 03 M3
Originally Posted by leletyM3 View Post
I just use BMW OEM
What he said. The OE fluid is excellent. When you pour a few ounces of Redline or RP in a cup and compare it to the OE spec that should be all the convincing you need.
A long 16mm (may be 15mm, I forget) box-end wrench will be your friend. The SMG has hydraulic lines that can make it tricky to get a ratchet on the first time you change the fluid.
Remove the fill plug first and you'll be set.
MisterM is offline   Reply With Quote
Old 06-15-2013, 08:09 AM   #23
Ky///m3
My Ride: 1988 E30 M3
Shockproof light weight plus champion friction modifier.
****ing awesome combo.
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline   Reply With Quote
Old 06-15-2013, 09:23 AM   #24
Lunatic
My Ride: 2007 335i
So is it in the same place as any other tranny?? That's the thing idk where anything is on smg, Idk where the fill or drain plugs are and is there anything different I have to do to it? Is it just drain tranny put plug back in and fill?? Or is there different things I have to do? Cuz ik smg is a regular 6speed but with an smg gearbox and idk if that makes it any different
Lunatic is offline   Reply With Quote
Old 06-16-2013, 10:19 AM   #25
MisterM
My Ride: 03 M3
Drain and fill plugs are identical. Only difference with the SMG variant is the hydraulic lines make the fill-plug hole access interesting. Last time I did it - it was just under 3 L on the drain and fill.
Good Luck.
Old 06-16-2013, 01:13 PM   #26
Lunatic
My Ride: 2007 335i
Thanks bro
Old 06-16-2013, 01:26 PM   #27
InDiGlOM3
My Ride: HPF M3 stg 2.5
Re: Tranny any DIff Oil
For you guys running redline, fck that. and royal purple? Really lol oem engine oem trans oem diff. Of os giken than whatever it recommends. I used redline before and transmission synco went out slowly. Who knows the real cause but i was running redline
