Australia
Old 11-16-2011, 05:58 AM   #1
ky0-325
My Ride: BMW e46 325i M-Sport
recaro sr3 into e46?
Hey all, I was wondering if it's possible to fit Recaro SR3's into an e46 sedan? I know the passenger SRS light will come on, but has it been done before?
ky0-325 is offline   Reply With Quote
Old 11-16-2011, 06:56 PM   #2
Ballistic325
My Ride: slow and steady
Don't know if it has been done before - try the Tech and Tuning forums...
On a related note, there are seat sensor bypass devices that you can buy online that should overcome the airbag warning light issue.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-16-2011, 07:18 PM   #3
M3_Aaron
My Ride: E46 M3
Its possible, I have Recaro SR4 Impact Pro seats in my M3.
You'll need an E46 specific bottom mount style seat rail with the a bracket for the standard seat belt buckle. Recaro make one but I couldn't find a dealer willing to sell me one. Macht Snell were also developing bottom mounts but I am not sure if it eventuated. I used Corbeau on mine but would recommend Recaro if you can find a set.
Regarding the airbag sensor your options are to either bypass it (there is a resistor kit available) or to install an OEM occupancy sensor mat like you would find in your original seats.
There is a mesh lining on the underside of the seats which allows you to slip the sensor mat into place, the mat runs around $180. To not trip the airbag light you'll have to keep the battery disconnected during the whole install.
M3_Aaron is offline   Reply With Quote
Old 11-17-2011, 06:22 PM   #4
ky0-325
Thanks for your replies. Is there a sensor for the drivers seat other than the seat belt buckle?
Old 11-17-2011, 06:39 PM   #5
M3_Aaron
My Ride: E46 M3
You don't need a sensor mat for the drivers seat.
Old 11-17-2011, 06:42 PM   #6
BMW E465
My Ride: 1dirty5
Awesome reply Aaron!
When i installed bucket seats into my car (non bmw) i used seats from the same manufacturer. Everything was pnp (other than the mount). So i suggest if you can find some recaro seats from the older bmw m range... I forgot which model came with them, but damn do they look good and fit the part. Hmm were they from the jps range?
Sent from my GT-I9000 using Bimmer App
BMW E465 is offline   Reply With Quote
Old 11-17-2011, 08:33 PM   #7
Tiag46
My Ride: e46
I had SR3's in my old car. Nice and snug
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
