Old 11-16-2011, 11:15 PM   #1
nitrorocket
My Ride: 01 A6 & 01 540I
Doing major work to 2005 X5 4.8IS, Which software to buy??
I will be changing many things on the 4.8is. What is the best software that allows the ability to code the ecm and bcm basically I need to have access to change anything. Does this exist?
I would like the ability to change parameters, delete functions, delete pids, etc.
I see alot of software out there and dont want to be uninformed and buy the wrong stuff.
Thank you.
01 Audi A6 STAGE 3+
01 BMW 540I W/M Package
nitrorocket is offline   Reply With Quote
Old 11-17-2011, 12:46 AM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Thank you.
Here.
http://oetuning.com/index.php/produc...lvetronic.html
Welcome to E46Fanatics.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 11-17-2011, 11:42 AM   #3
nitrorocket
So that is the software to completely change and modify my ECM/BCM myself?
Kinda looks like a flash or something...
01 Audi A6 STAGE 3+
Old 11-17-2011, 07:21 PM   #4
Rob43
Rob43's Avatar
Call OE Tuning, I'm quite sure you need to send them your ECU. If you need it done fast, use overnight shipping to & from. But check first to see if there's a OE Tuning dealer within driving distance.
Good luck.
Old 11-17-2011, 08:11 PM   #5
nitrorocket
Nobody is capable of tuning my truck for the purpose that I need, so I need to do it myself... I am looking for the actual SOFTWARE that will tune the vehicle, not a flash from some other tuner...
01 Audi A6 STAGE 3+
Old 11-17-2011, 09:51 PM   #6
Rob43
Rob43's Avatar
OK,
I tried to help.
Good luck.
Old 11-17-2011, 11:00 PM   #7
nitrorocket
Thanks for the input, I should have explained what a complex project I am doing...
Thanks!
01 Audi A6 STAGE 3+
