Old 11-17-2011, 10:25 AM   #1
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Need opinions! P0171 Code only. 281E on Peake tool.
Just some background, my CEL stays on because of my headers so every 2 weeks or so I hook up my scanner to make sure those are the only 2 codes. Last week I put my stock intake back on and a few other things cosmetic related. While I was in there I noticed the VCG has a tiny, tiny leak. When I ran the codes I got the normal 2 codes as well as a P0171 (lean bank 1). Hooked up my peake tool and got a table 20 code, 281E (air intake system:activation). I cleared the codes and it came back. I figured it was the leaky valve cover gasket, so last night I replaced that as well as my thermostat because it was randomly sticking open. No luck. The intake boots are fairly new and no cracks. Disa valve is fairly new but I suppose it could be the gasket leaking. I can hearing a sucking noise like a vacuum leak coming from near the and/or under it. I am stumped because it is only lean on 1 bank and not both. Any opinions or experience with this?
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 11-17-2011, 10:47 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
It's not uncommon for a minor vac leak to trigger a code on only one bank. The sensor readings are never 100% identical in both banks, thus if you're just barely running lean enough for it trigger a code, one bank can reach that threshold before the other. Once it gets a little worse, it will trigger both banks.
However, it's also possible to have a leak at an injector o-ring, clogged injector, failing O2 sensor, etc that is truly causing it to be lean in only one bank. This is far less likely though than simply having a very minor leak somewhere in the intake tract (such as around the DISA where you think you might hear a leak).
Old 11-17-2011, 10:50 AM   #3
E46_330i_Stud
Thanks! Yea it makes sense that it's a minor leak because I have no symptoms. It idles fine when cold and runs 100%. I'm going to pull the disa and reseal it
Edit: to test my O2 sensor I can just swap them at the connector, clear codes and see if it swaps to bank 2 correct? Or do I have to physically swap the whole sensor?
Old 11-17-2011, 11:37 AM   #4
TxZHP04
No, swapping O2 connectors will cause all kinds of problems (reference the countless posts around here of people doing this by accident when installing headers). I wouldn't worry about the O2s until you exhaust all other possibilities. Intake leak is still your most likely culprit.
Old 11-17-2011, 11:47 AM   #5
E46_330i_Stud
True, I knew I couldn't because I did that when I did headers. Just forgot lol. I will pull it apart this weekend.
Old 11-17-2011, 01:40 PM   #6
E46_330i_Stud
Update: I found on Endtuning.com that their definition of the 281E is "Disa Intake System Output Stage". Failing disa or is this referring to the leak?
Old 11-25-2011, 06:48 PM   #7
E46_330i_Stud
Fixed! Disa gasket was the culprit. Hope this thread helps anyone out in the future!
