Old 11-17-2011, 03:25 PM   #1
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
Diagnoses Needed *vid included* Bad Valve Guides?
Heyyyyyyyyyyyyyyy there to basically what is the "na forum" lol
I think my valve guides are going! On engine braking my car burns oil. I changed my CCV and all the hoses applicable to them. I have already checked my connections to make sure they are tight. I have also changed the VCG. Yet my car still smokes.
Do you guys have any other possible ideas of things that it could be?
My whole thing is that i don't think it's the valve guides because of the amount of oil, and because my car is only at 128k. but i have no clue where else to look.
here is the video. it gets to be very evident @ 40 seconds, 1 minute, and 1.15 but you can see me burn oil the whole way down if you really look at it.
to set the scene of the video, i'm in 5th gear all the way down, engine braking @ maybe 1500-2000rpm. when you see the big puffs, it's when i get on the gas a little.
p/s i don't usually burn oil normally on the street, er should i say, not as noticeable as this video.
thanks for the help,
-Raj
SL Blak Soldier is offline   Reply With Quote
Old 11-18-2011, 04:42 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
No help here, but I'm lauging at diag noses.
Maybe a retrofitted e36 lsd would help?
Old 11-19-2011, 07:34 PM   #3
SL Blak Soldier
maybe. lol.
i finally had some time to look over the car today. looks like my VCG that i just changed less than 3k miles ago is leaking again.
Old 11-21-2011, 02:16 PM   #4
Blocked Out
My Ride: Imola 330i M-Sport
VCg has nothing to do with it.
It could possibly be valve guides but until you get a leakdown you wont necessarily know. It could also be a number of things, from a simple vaccum leak preventing your CCV from properly functioning causing an abnormal crank case pressure, to worn out piston rings.
You need to start by eliminating the easiest and less expansive things from the list. Check each and every vaccum line to and from CCV and your intake mani as well as vanos lines, get a leakdown , get a different oil in there (i dont know what youre using now so I cant say, but go from Castrol to some expensive oil like Royal Purple 5W40, Motul 300v 5w40) .
Just pray its not your piston rings, everything else is cheap and easy to replace.
Original BMW Teile ///
IMG_1725
