E46 Xi Forum
Old 11-18-2011, 04:58 PM   #1
rosshc44
My Ride: 2004 325xi
325XI 2004 Squealing Brakes
Hey,
My brakes have been squealing really badly since the fall started and now that its really cold, they have started squealing when braking at higher speeds on the highway, not just when stopping. I just had my summer tires swaped for the winters and they checked my brakes and said they were fine and had plenty of life left. They told me the squealing was because of the material. Is there anything i can do to minimize the squealing other than getting newer pads/rotors?
Thanks for your time.
rosshc44 is offline   Reply With Quote
Old 11-18-2011, 05:16 PM   #2
kylek325i
My Ride: 2003 325xi sport
clean and put some anti-squeal compound on the backs of the pads and make sure the anti-rattle spring clip is secured on the calipers. Find a brake DIY in the DIY forum. Also check the torque on your lug nuts...i go to 88.5 ft-lbs. dont take a shops word if the brakes are "fine", if the pads are almost worn out and the rotors are grooved its time to replace.
kylek325i is offline   Reply With Quote
Old 11-19-2011, 12:23 AM   #3
fastjasonbmw
My Ride: 330Xi
Also alot of cheaper "brake shops" install inferior pads and rotors that tend to be noisy over time/use. Sometimes the rotors just get glazed due to slight braking pressures (stop & go). Try doing some very heavy braking to minimize the glazing.
Sent from my HTC Glacier using Bimmer
fastjasonbmw is offline   Reply With Quote
Old 11-19-2011, 08:08 AM   #4
Kubica
My Ride: 2003 325xi
What kind of pads do you have?
Just a little anti-squeal goes a long way.
