E46 Xi Forum
Old 11-20-2011, 02:45 AM   #1
Doug in Lakeview
My Ride: 2002 325xi
Next Project - Suspension System Rebuild - Any Suggestions?
Hi all,
I have a 2002 325Xi (non-sport package) all stock except for 18 x 8.5 CLS style wheels with Michelin Pilot Sport A/S P245/40 ZR 18 tires. ~114,000 miles on the odometer.
Will be spending the Thanksgiving holiday weekend in the garage replacing right (and possibly left) front axles. See prior post as to why I need to change out complete axle instead of just CV boots. Suggestion: If the CV boot is torn do not delay in replacing the boot!!
Next project is to install springs (front & back), front struts, rear shocks, front control arm bushings, and rear trailing arm bushings. I will be doing all of the labor myself.
The car is a daily driver used here in the city and for nice long drives out into the country. I am considering installing the following:
Eibach Pro Kit Spring Set
Koni Sport Yellow - Adjustable Front
Koni Sport Yellow - Adjustable Rear
Powerflex Urethane FCAB & RTAB
Any comments/suggestions? I have read through all of the previous posts on this subject here on the forum. If I did not go with the above I would probably go with the H&R Sport Spring Set and Bilstein Sport Struts/Shocks.
Also, while I am doing the above install is there anything else I should consider?
Thanks,
Doug in Lakeview
Doug in Lakeview is offline   Reply With Quote
Old 11-20-2011, 04:14 AM   #2
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Good choices for spring set and shocks/struts and bushings. I just installed a set of Powerflex Urethane Front Control Arm Bushings (had to replace a lower control arm that had a bad ball joint). If you need any tips on removing the old bushings and installing the new Powerflex ones, drop me a private email, be glad to give you some pointers (reyomot@verizon.net).
H&R springs are also good (I've used them a lot) and Bilstein Shocks and Struts are also good and a little bit cheaper than Koni, however not adjustable.
Other things to consider while doing this; front and rear stab bar replacement or front and rear stab bar links, front shock tower brace, new rear upper shock mounts and don't forget to check your steering tie rods and front inner and outer ball joints on the control arm. When I have replaced spring sets, I always replaced all the rubber parts that the springs set on and the upper front bearing assembly, and all bushings front and rear, and the front lower control arms and ball joints. That way you have a complete, brand new suspension system and no need to go back in there to replace parts for a while.
tomoyer is offline   Reply With Quote
Old 11-20-2011, 10:39 AM   #3
Kubica
My Ride: 2003 325xi
Definitely go with powerflex! Good choice. Use the centered e36 m3 powerflex fcabs and the normal e46 rtabs.
If you go with bilsteins, use e36 m3 sports in the rear.
Old 11-20-2011, 08:07 PM   #4
e46alfonso
My Ride: 330xi MT, mustang gt
i ended up getting the stock cab just last week because bavauto said that the e36 m3 don't fit. im going to return these and aks them about the "centered" ones.
a part#.... would be very helpfull. thanks
Old 11-23-2011, 10:14 AM   #5
e46alfonso
i got the powerflex e36m3 cabs and im concerned. the center hole of the bushing is round and the control arm end is not. will this fit?
Old 11-23-2011, 10:37 AM   #6
Kubica
My Ride: 2003 325xi
^Control arm end IS round.
Old 11-23-2011, 10:47 AM   #7
e46alfonso
thanks a lot i didn't know
