#41 | |
Yup, thats what I tried to do. Have all the tools(including the extractor and drill bits) and tried the process you described. But to keep the Drill bit along the axis of the screw is impossible because of the size of the Drill I have. I have a cordless black and decker 12V drill. The little metal partition between the strut tower and DME gives me no room at all to have the drill straight. May be I need to get a smaller drill to clear the metal barrier between the strut tower and DME fuse box. Also I do have T40, but at that time something made me use T30 Small mistake cost me so much frustration.
#42 | |
#43 | |
#44 | |
#45 | |
This weekend I am going to try with the grinding tool to completely grind away the bolt and see if it works out.
#46 | |
http://www.dremel-direct.com/acatalo...FbMbtAod0BwAkw Maybe something like that, and a lot of patience, could get the head off. Another thing. What about using the center punch to try and turn it. Position the punch on the edge, at an angle, and tap away. |
#47 | |
Just to give you a picture of what I tried and how mangled the screw head is, here are couple of pictures from the phone I took just now. I know they are blurry but you get the picture. ![]()
![]() Last edited by trj; 11-16-2012 at 11:03 AM. |
