Old 11-20-2011, 09:35 PM   #1
cyberlando
My Ride: 2002 M3
Powder coat
so i got two problems here..........im trying to find a color that matches these rims here.......i came to a conclusion that its a hyper black or high gloss black. do you guys agree? im trying get as close to that color as possible!
second problem is that the guy who said he was gonna sand blast my rims quit....so im left with the problem i sanded 2 of them pretty much most of the way......but now im starting on my third rim.....is there any stripper out there stronger than aircraft paint remover that will do the job.........
i used aircraft for the first two and its a slow hit or miss process!
ID:	426003   Click image for larger version
ID:	426004   Click image for larger version
ID:	426008   Click image for larger version
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 11-20-2011, 10:05 PM   #2
Sanchjer
My Ride: 323i e46 SOLD!
There's a chemical called Kleen-wall. Stuff is intense, we use it at work, removes almost anything. Not sure where you as a consumer can buy it but use Google and see what you can find. GL
Sent from my PG86100 using Bimmer
Sanchjer is offline   Reply With Quote
Old 11-20-2011, 10:15 PM   #3
cyberlando
My Ride: 2002 M3
nahhhh thats not strong enough just looked it upp need something alot stonger than that but also something that doesnt eat the alluminum
Engine:
Interior:
Old 11-20-2011, 10:19 PM   #4
RKiepper
My Ride: 1999 E46 328I x2
Your not the only one with this problem. I posted the same question a few months back, no help at all. The brush on aircraft stripper is the most cost effective off-the-shelf solution. It would be nice if it took less then a whole can per wheel though, and all it really does is soften the powder coat. Sandblasting will be hit & miss too, the stuff is like super powdercoat.
The best thing to use is brake fluid. But good luck finding a large enough source to submerge even part of the wheel. I haven't had such luck as most shops throw it in with the used oil and burn it for heat in the winter.
RKiepper is offline   Reply With Quote
Old 11-20-2011, 10:28 PM   #5
cyberlando
My Ride: 2002 M3
brake fluid....and that WOrks?? for sure faster than aircraft? i need a definite answer on this one!
Engine:
Interior:
Old 11-20-2011, 10:46 PM   #6
RKiepper
I've done considerable research on this matter as well. I have definitive proof, just no pictures. On my first 46, the front drivers wheel had an entire section stripped down to bare aluminum. When it belonged to the previous owners, the caliper had leaked, either through a blown seal or loose bleeder screw. it ran down the rotor onto the inside barrel of the wheel, it puddled in the wheel and took everything with it. They used it as a weekend car so it sat for a few days like that.
Old 11-21-2011, 04:06 AM   #7
Alex323Ci
My Ride: M3 & 323Ci (sold)
well the Hyperblack is a very hard finish to do. there was a place or two that i remember doing it but it was expensive. so much so it' was basically cheaper to buy wheels with that finish since it's sort of like a black chrome.
many of the powder coating places will offer a sandblasting service if the wheel is going to be completely powdercoated.
Old 11-21-2011, 09:57 AM   #8
Sweetness
My Ride: '01 325i
Sandblasting will take it all off
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 11-21-2011, 10:12 AM   #9
djewen
My Ride: M3
Send a message via MSN to djewen Send a message via Yahoo to djewen
Originally Posted by successor View Post
sandblasting will take it all off
+1
You can sleep in your car but you cant race your house...
Originally Posted by Fly330ciGuy
can you come over and take alook at it i dont know where my fuel pump is. i tried asking in the general e46 forum and they just told me to stop posting and to stick a steak in my engine
djewen is offline   Reply With Quote
csl, paint, powder coat, rims, stripping
