E46 Xi Forum
Old 11-20-2011, 11:02 PM   #1
heejshin
My Ride: 01 330i
Rally Setup
hey got bored of just doing exterior work cuz my car is an auto and ive come to terms that it will never be fast. ive autoXed in the past with different cars and i want a change of scenery.
sooo with that said, i wanna try rallyX (LIGHT rallyX lol)
i need ideas for suspension setup.
right now im running HR sports on stock shocks
ASA 18x8 with 245/40/18 all around
stock everything else
my plans:
stock springs
Blistein HD
16x7 with 215/55/16
and bars bars bars.....
i need sway bars, x brace, etc.
my question is where do i find these suspension components for the XI i cant find ANYTHING!!! help!
heejshin is offline   Reply With Quote
Old 11-20-2011, 11:30 PM   #2
White_Knuckles
My Ride: 2003 325xi
Wow. That's different. Rally on brother!
All I see from watching TV, is scary Euro events hanging it out there, in a full cage Subar-something, going nutty fast, sideways on mud or slime, usually ending up in a fiery crash roll-over. Looks great.
Old 11-21-2011, 12:12 AM   #3
Tarmac_E46_M3
My Ride: 2003 M3
Unless you're doing serious rally events, 17x7 to 17x8 wheels would do fine. if you're running in gravel you can run 225-235 wheels; snow, you would need something around 215-225 wheels.
You will want to run a slightly bigger sidewall than recommended, it will throw your RPMs off a bit, but will be better for the gravel terrain.
I would find gravel springs that fit your stock struts. I forgot the name, but it's like something-king springs. Not sure if they have them for the e46 though... You could probably pull springs from a X3 or something, if they fit onto your struts. you're going to want to raise the car at least an inch for rally cross; if you want to be fast through the courses.
I'd run the stock sways for now, since you will need MORE wheel travel on gravel courses; or really, any rally course. See how they handle, and adjust from there. Might just keep the stock sway and pull the rear sway off; won't know until you get out there.
coming from an STI background... and a HUGE rally fan Ask any question, I'll do my best to help.
2012 MINI Countryman All4
A Compilation of Modifications
Previous: 1969 Mustang, 2006 STI, 2009 STI, 1995 M3, 2003 M3.
Tarmac_E46_M3 is offline   Reply With Quote
Old 11-21-2011, 10:58 AM   #4
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
rally-crossing an e46 seems like a terrible idea *shrug*
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 11-21-2011, 11:03 AM   #5
Tarmac_E46_M3
My Ride: 2003 M3
Why?
People rally cross brand new WRX's and STIs (ranging from 28k-38k OTD). E46 xi, if anything, would be the budget AWD vehicle to use, since they are well balanced and quite inexpensive.
Rallyx isn't really too extreme, terrain is quite flat, for the most part (in compared to profesional rally courses). it would be different if he was doing stage rallies... then he will definitely need to do a bit more than wheels, tires and suspension.
Old 11-21-2011, 11:17 AM   #6
redbull 325is
My Ride: 325xit/6
Originally Posted by Tarmac_E46_M3 View Post
Why?
xi front axles and diffs can't quite take the repetitive abuse of grocery-getting, not sure how they will handle the abuse of constant loose terrain at speed. I'm sure the vehicle would be plenty fun, but I'm not convinced of how well it'd would cope.
Old 11-21-2011, 11:20 AM   #7
Tarmac_E46_M3
My Ride: 2003 M3
Well... that sucks for that AWD drivetrain, maybe a sway of a certain parts will make it a bit stronger under those conditions.
Hopefully, for his sake, they do hold up!
Old 11-21-2011, 12:00 PM   #8
Kubica
My Ride: 2003 325xi
You can definitely rallyX an xi!
Probably want to keep the stock springs, and get some bilstein HD struts/shocks, powerflex fcabs/rtabs, strut tower bar, schroth harness, and some better brake pads. Definitely reinforce the rear shock mounts, possibly with a shock tower brace.
I have an old set of studded nokian hakkapeliittas in 205/55/16 that do really well on dirt roads and loose gravel.
Also, I think a manual tranny is a must.
Old 11-21-2011, 12:04 PM   #9
Tarmac_E46_M3
My Ride: 2003 M3
^^^ Manual is a must...
You can always run inexpensive snow tires and just throw them on backwards to grab the gravel better.
