Old 11-21-2011, 02:09 PM   #1
Bella_Bimmer
My Ride: 2004 BMW 330Ci
Xenon HID malfunctioning
Real quick problem with a quick diagnosis hopefully... My front right Xenon HID bulb is not working (on the dash I get the little car logo with a red low beam logo on the front-right side of the indicator). I've swapped the bulbs, ignitors and now ballasts and the problem still persists on the right side. If it is none of the above components.. then what in the world could it be? I've checked the fuses as well, just to be sure. Anything helps! Thanks you.
Bella_Bimmer is offline   Reply With Quote
Old 11-21-2011, 02:30 PM   #2
Vic328CSi
My Ride: depends on the mood
Check for voltage before the ballast to make sure its recieving 12v to begin with to rule out something. Too many variables right now. If u get voltage at the ballast then its an issues further downstream and not upstream.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 11-21-2011, 02:55 PM   #3
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Disconnect the battery for 10 minutes and reconnect it...then try it.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
ballast, bulb, headlight, hid, xenon
