Help w/ brake squeal and wheel vibration - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-23-2011, 04:50 AM   #1
browniesong
My Ride: a car
So I was driving my car and noticed that my brakes are squeaking pretty loudly. Obviously my first thought was to replace the brake pads, however I had recently replaced all pads and rotors (within the last month) and they don't seem to be anywhere close to shot. I also noticed excessive steering wheel shake when applying the brakes at higher speeds (getting off the freeway at 60+ mph). After checking the calipers to check for locking, I found everything to be in working order, yet it still has rough braking. Any ideas as to what could be causing the problem? I'd appreciate your input on this! Thanks in advance
Sent from my Nexus S 4G using Bimmer
browniesong is offline   Reply With Quote
Old 12-12-2011, 06:17 PM   #2
JamesR320
My Ride: BMW 320D
your problem could be warped brake disc , an idea could be to change your brake disc .
JamesR320 is offline   Reply With Quote
Old 12-12-2011, 08:36 PM   #3
Sansho
My Ride: 2001 325i
See this article on The "Warped" Brake Disc and Other Myths of the Braking System by Carroll Smith
Sansho is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-12-2011, 09:57 PM   #4
Poling00_328i
Banned
My Ride: 2000 328i
I have the same issue with mine as well. I am figuring on warped rotors or you have knocked a wheel weight out. I seem to get a slight shake in my steering wheel when just driving, that I am figuring is a wheel weight is thrown off.
Hope this helps
Poling00_328i is offline   Reply With Quote
Old 12-13-2011, 02:01 AM   #5
browniesong
My Ride: a car
Hey all, thanks for the responses. I replaced the brake disc and it seems to have helped the brake squeak. As for the wheel vibration, it feels better but not perfect. Nothing that I can't get over. I might take it in for an alignment to see if that helps.
