Old 11-25-2011, 10:41 PM   #1
ducky328i
My Ride: modded '97 328i/5
Send a message via AIM to ducky328i Send a message via MSN to ducky328i Send a message via Yahoo to ducky328i
E46 M3 LTW flywheel/clutch options
I posted this in the E46 M3 section, but after numerous views, and zero posts, I assume this may be the more appropriate place to inquire. I'm in the process of fitting an E46 M3 6 speed gearbox into my 97 328i and I'll have to use a flywheel and clutch setup for an E46 M3. So far I've found the UUC LTW flywheel/clutch setup, and the comparably priced JB offering from bimmerworld. What are all of the options for this application and what is the most popular/recommended?
- UUC - Powerflex - DDM - Borla - KONI - H&R - OEM BMW - AKG Motorsports -
ducky328i is offline   Reply With Quote
