Old 11-26-2011, 01:23 PM   #1
mildon77
My Ride: 02 330i
Rear subframe reinforcement as preventative main??
My car has no sign of subframe damage. Its an 02 330i with 150k miles, I havent dropped the rear crossmember to really check it out properly.
My question is would you do the subframe reinforcement to prevent future damage or just wait and see how it goes? Thanks
mildon77 is offline   Reply With Quote
Old 12-01-2011, 01:19 PM   #2
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
I have been told that bumpy roads and salt are contributing factors to the failure. With 150K miles, at the very least a visual inspection will put your mind at rest.
Jim
Jim Murphy is offline   Reply With Quote
Old 12-02-2011, 06:25 PM   #3
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Apparently, rear subframe failures are caused by bad rear subfame bushings...my guess is that yours are close to the end or dead already. No way to know without dropping your whole rear.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-02-2011, 06:54 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
That's the first I heard this. When they fixed my subframe at around 200K miles, they said my bushings were fine...so you've got me curious. I thought these were junks hunks of rubber, not fluid filled like the motor mounts or CABs.
I thought the defect was that the floor was too thin to support the loads and that over time metal fatigue sets in and starts them tearing around the subframe bushing.
In any case, OP, there are aftermarket reinforcement pieces that guys have had welded in. There's also the foam epoxy mitigation approach. Foams are injected to reinforce the area between the two floors in the trunk above the rear bushings. That would be the cheapest and worth a try...but I don't know what then welding around that might do...probably not good for the foam.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 12-02-2011, 07:11 PM   #5
bigjae1976
bigjae1976's Avatar
Many experts have come up with this theory. Basically the subframe bushing goes bad which causes excessive movement in the rear suspenion carrier/subframe. This then loads up the mounting points, especially on one side, forget which one. The loading and unloading fatigues the metal and causes the failure.
I've gone with PF subframe bushings to eliminate the failure prone rubber. Other have gone with solid bushings and reported good results. I noticed no increase in NHV with the poly bushings.
FYI, at 88k miles, I noticed my diff bushings were shot but the subframe bushings were still good.
Old 12-03-2011, 01:08 AM   #6
LivesNearCostco
My Ride: 2003 ZHP 6MT
I think the front left subframe mounting area is the most likely to fail.
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 12-03-2011, 02:12 AM   #7
Blocked Out
My Ride: Imola 330i M-Sport
Apparently, rear subframe failures are caused by bad rear subfame bushings....
This is absolutely correct.
First the diff bush goes and puts more stress on the subframe bushes , then they go and then your subfloor goes.
BUT E46s had subfloor failures as early as 20kmiles back in 2000, all true and documented by BMW. So you are never safe, but I would recommend new bushes simply as maintenance. Reinforcement plates would be overkill for a car with such low value already.
BMW realized that the desing of the rear subfloor is ch1t and tried fixing it in 2002 , thats when they introduced a new design of the whole rear subfloor (thicker and it even looks different) but the problem still shows up on cars build in '04 and even some very very late '05 build M3 with super low miles.
Point is, they tried but failed.
Rumor has it that the failures were due to the bad quality sheet metal used by BMW at some point and not teh design but this rumor is just a rumor.
Original BMW Teile ///
IMG_1725
Old 12-03-2011, 02:20 AM   #8
MSportBMW
My Ride: E46 325, EVO8 MR
Sadly the only real way to tell is to take it all apart then check it all out. Most likely when it's easily visible the condition of the subframe is dire...
Just do it when you have the cash or if you plan on keeping the car. And make sure you also replace corresponding bushings etc...
MSportBMW is offline   Reply With Quote
Old 12-28-2011, 03:00 AM   #9
huskerick
My Ride: 325i/C6/928/951
I did this on mine when installing the 3.91 diff and new bushings. It's a headache I wanted to eliminate.
huskerick is offline   Reply With Quote
Old 01-13-2012, 03:23 AM   #10
FM3T10
My Ride: E46
Basically once you get a reinforcement kit installed (Turner Motorsport's for example), the whole subframe problem should be gone correct?
FM3T10 is offline   Reply With Quote
Old 01-13-2012, 07:39 AM   #11
TxZHP04
My Ride: ESS TS2+ ZHP
With proper welds and rust prevention along with some fresh bushings, then in theory, yes. Didn't work out that way for me but my car is also heavily modded and experienced a diff failure which lead to an unusual shock load on the subframe which may have been largely responsible for my second round of problems.
Old 01-14-2012, 06:00 PM   #12
FM3T10
My Ride: E46
I'm terrified of Subframe Mounting Failure. Any good shops around Houston TX that KNOW how to install the Reinforcement kit for a good price?
