Sponsored by BimmerWorld
Old 11-26-2011, 08:08 PM   #1
dcr33313
My Ride: 2005 330i ZHP
Very Mushy Brakes after a Rotor/Pad Replacement
I just had my rotors and pads replaced on my ZHP, as well as have the brake fluid replaced, and now I have to press my brake pedal almost all the way down for them to start working. The guy who put the rotors on also put the drilled/slotted rotors on backwards (left of the right side and vice-versa). Does anyone know a way to fix this or if this problem might have to do with the placement of the rotors? FYI, Im getting the rotors fixed tomorrow.
Thanks for any help.
dcr33313 is offline   Reply With Quote
Old 11-26-2011, 09:56 PM   #2
invictus
My Ride: M3 (F80 & E46), S3R
he didn't do a very good job replacing brake fluid. time to bleed them again.
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 11-26-2011, 09:57 PM   #3
invictus
also drilled ftl.
The story so far...
Fund my track car:
Old 11-26-2011, 10:25 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You should get everything fixed tomorrow. The slots going the wrong way are not the issue.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-26-2011, 10:27 PM   #5
deadpass
My Ride: 01 330i
Sounds like air in the brake lines, make your "mechanic" bleed them again
deadpass is offline   Reply With Quote
Old 11-26-2011, 10:59 PM   #6
Thotfulspot
My Ride: 2003 330Xi
Brakes need to be bled again. It's not uncommon to have to do it several times.
Thotfulspot is offline   Reply With Quote
Old 11-26-2011, 11:07 PM   #7
dmax
dmax's Avatar
Though it should be uncommon that a mechanic doesn't know how to bleed brakes.
As a diyer, that's one thing. As a shop, that didn't drive the car or at least push the pedal down...not good at all.
Mangofy your E46!
Old 11-27-2011, 12:06 AM   #8
Thotfulspot
My Ride: 2003 330Xi
If the shop couldn't put the rotors on correctly, I can understand them not bleeding them correctly. It also depends if lines were changed or if they let the fluid level get too low while bleeding. I've always bled them then drive the vehicle to get the air out then refill the MC and do it again.
I'd rather have a shop do it thoroughly than just put a power bleeder on and call it a day.
Old 11-27-2011, 05:55 AM   #9
dmax
dmax's Avatar
OP, before you start the car next, just pump the brake pedal until, maybe, it becomes firm. Then start the car and see what you get. If that doesn't work and the shop has an issue getting rid of the mushy feel, then it's likely the brake fluid level dropped too low in the reservoir and air got in the ABS system. In that case, the shop needs software to cycle the abs to bleed it...from what I know. If it's just a local garage, it might not have this software.
And Thotful, you're right, the shop messed up the rotors...unless OP was wrong about that. I don't like rotors that are like women myself, so never had that issue!
Out of curiosity, if anyone knows, how would reversing slotted/drilled rotors affect their performance?
Mangofy your E46!
Old 11-27-2011, 09:59 AM   #10
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Bedding in the pads will help.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-28-2011, 06:04 PM   #11
dcr33313
Ok, thank you everyone. I'll look into getting the system bled again, it's just hard because I'm at school now. Should I go to the local BMW dealer (BMW of Gainesville) or should I look for another mechanic? The last place I went had more than thirty great reviews, so I'm hesitant to go someplace other than the dealer.
Old 11-28-2011, 08:49 PM   #12
bigjae1976
bigjae1976's Avatar
Try the bedding procedure on Stoptech's website first. New pads will feel mushy and have no bite until they are bedded in. Then bleed if the pedal still feels mushy.
Old 11-28-2011, 08:59 PM   #13
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
x2
Also, I would do a Vacuum Bleed. Can borrow the tool from Autozone for 55 bux and will be refunded once tool has been return.
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
brake, brake fluid, brake pedal, pads, rotors
