Old 11-19-2011, 10:02 PM   #1
webbashl
My Ride: 04 325i
Pop when backing up and pop when taking off
I have an 04 325i 5 spd 46k and I have noticed a low sounding pop noise from the rear when I back up and then a pop when I go forward. It will do each time i back up and then go forward, also have noticed it when i take back off after a sudden stop. I have searched but nothing seems to answer my question. Thanks Ash
webbashl is offline   Reply With Quote
Old 11-19-2011, 10:07 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
check subframe.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-19-2011, 10:16 PM   #3
webbashl
My Ride: 04 325i
I read a few threads on that but i thought that problem was on preface? How do I check that?
Old 11-19-2011, 10:17 PM   #4
jasonbimmer
get under the car?
it could also be driveshaft play, diff bushings.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 11-20-2011, 01:01 AM   #5
MntnTwisties
My Ride: 04 325i
I had a really loud popping from the back end when i backed up it ended up being a badly broken wheel bearing
MntnTwisties is offline   Reply With Quote
Old 11-20-2011, 01:13 AM   #6
zhenkaaaM3
My Ride: Fst'r then your e46
+1 on mounts
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 11-20-2011, 01:22 AM   #7
e46hellrot
My Ride: e46
got that too
e46hellrot is offline   Reply With Quote
Old 11-22-2011, 08:02 AM   #8
webbashl
My Ride: 04 325i
Originally Posted by E46tknv View Post
+1 on mounts
Which mounts? I noticed sometimes it will do it in second after I release the clutch from coasting. Also let me clarify it pops once not multiple pops.
Old 11-22-2011, 08:12 AM   #9
Xelo
My Ride: '01 E46 320i
The differential has developed a play in the attack pinion. You can't do much about it.... drive it until will eventually fully fail (which might be many tenths or hundreds of thousand miles).
Xelo is offline   Reply With Quote
Old 11-22-2011, 08:51 AM   #10
Brinkley
My Ride: 99 328i, 07 z4 3.0
The subframe on e46f is kind of like Lupus on House, if you're not sure what the problem is, throw out subframe, see what that gets you.
It's probably a rear differential bushing worn out, I would HOPE that an eight year old differential isn't already failing, or something in the rear suspension. You need to get car in air and do a good inspection of rear of car and see if you find the culprit. If there is no obvious worn out/cracked bushing, then try manipulating the driveshaft/axles to see if you can reproduce sound.
Brinkley is offline   Reply With Quote
Old 11-27-2011, 04:02 PM   #11
aaronk68
My Ride: 1999 323i
could also be a rtab bushing... mone sort of pop'd when the bushing was blown out... is your driver side rear tire wearing alot? if it is the rtab bushing failure alllows the tire to toe out while driving and the car is squirrly as hell on wet / slick pavement...
aaronk68 is offline   Reply With Quote
