Old 11-27-2011, 07:12 PM   #1
BeMyWhip
My Ride: 01 BMW 330ci
Easy DIY: Headlight/fog light restoration...
Picked up a cheap $9 headlight restoration kit from turtle wax. Better than($25 for) mothers or that company... how do you spell it... maquiars, whatever. anyway, it comes with 4 stages of sanding and the polishes. only thing missing was the polishing pad (so I used my big car polishing pad and polisher) it worked great. here are some before and after of the headlight lenses, and fogs:
ID:	426800   Click image for larger version
ID:	426801   Click image for larger version
ID:	426802   Click image for larger version
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 11-27-2011, 07:27 PM   #2
Aj20034
My Ride: 330ci, 535i F10
Wow good result and tips? Did you do anything diffrent?
Sent from my SPH-D700 using Bimmer
Aj20034 is offline   Reply With Quote
Old 11-27-2011, 07:35 PM   #3
BeMyWhip
Just buy the kit at autozone; turtlewax: comes with 4 mini sanding pads. you use the lubricating spray as you sand fron #1 to #4; then apply polishing compound, smear it on the lense and polish it with a polishing pad, wipe clean. If you like the results apply the sealant wipe and allow to dry for 24hours, if youre not happy repeat sanding from #1 to #4. I did everything twice! Not hard, but the results are worth it.
Always Mod!!!
Old 11-27-2011, 08:04 PM   #4
Sanchjer
My Ride: 323i e46 SOLD!
TurtleWax ftw! Never buy anything different to clean Crystal.
Sanchjer is offline   Reply With Quote
Old 11-27-2011, 08:09 PM   #5
afstud
My Ride: 2003 ZHP 6-speed
i restored my headlights and foglights as well with "new looking" results just using 400, 1000 and 2000 grit sand paper and Meguiars PlastX on a buffer pad to buff them out to a beautiful shine. Also eliminated all the stone chips.
afstud is offline   Reply With Quote
Old 11-27-2011, 08:13 PM   #6
Sanchjer
^see I would be all for doing this much work but when you can buy a new pair of headlight lenses for just $70, I'll buy a new set.
Old 11-27-2011, 08:16 PM   #7
BeMyWhip
$9 to do lenses and fogs! Not bad!
Always Mod!!!
Old 11-27-2011, 08:17 PM   #8
afstud
only took me an hour and half to do all mine and saved 70 bucks...well worth it.
Old 11-27-2011, 08:31 PM   #9
6spd330i
My Ride: imola 330i salOOn
cool!!!!!, thanks for the diy.
6spd330i is offline   Reply With Quote
Old 11-27-2011, 08:33 PM   #10
BeMyWhip
Wink
Agreed. Was fun and had a few drinks.
Always Mod!!!
Old 11-27-2011, 08:43 PM   #11
BeMyWhip
You saved more than $70; the cheapest ive seen lenses was $72 + shipping, well over $80; plus dont forget the fogs... Well over $70 - $80 per pair shipped. Thats over $150 in savings plus the fun of doing it yourself.
Always Mod!!!
Old 11-27-2011, 08:45 PM   #12
afstud
your right......and the satisfaction of knowing you put the hard work into it.
Old 11-27-2011, 09:14 PM   #13
Johal E32
My Ride: BMW's
Looks good, I should probably do this on my e46 sometime...lol
Johal E32 is offline   Reply With Quote
Old 11-27-2011, 09:36 PM   #14
greenskycity
My Ride: 1999 328i
I tried the Turtle Wax kit and it looked OK for a while but faded eventually, I then did it with the 3M kit and it looks good still, so.......
http://forum.e46fanatics.com/showthr...301&highlight=
Green
greenskycity is offline   Reply With Quote
Old 11-27-2011, 09:45 PM   #15
BeMyWhip
Green
They all basically work the same, your paying for the brandname.
Always Mod!!!
Old 11-27-2011, 09:50 PM   #16
BeMyWhip
greenskycity, you like power tools, however, you have to keep in mind that sanding should be vertical or horizontal or you will get swirl marks. not good. has to be done by hand, the polishing can be done with a powertool.
Always Mod!!!
Old 11-27-2011, 11:04 PM   #17
Bimmerguy82
My Ride: 2004 ZHP 6 SPD
I looked around a bit a didn't find any place that sells replacement lenses for 2004 and up coupes. Anybody know?
BMWCCA member #407674
___________
-Joshua
ZHPMafia.com member
Ebay headers | 3.38 diff | 2.5" cat-less exhaust | K&N intake | AA stage 1 software | UUC stage 1 light flywheel and clutch | UUC Evo 3 ssk
Bimmerguy82 is offline   Reply With Quote
Old 11-27-2011, 11:14 PM   #18
Zell
Zell's Avatar
My Ride: so turbo wow
That's awesome! I was thinking of doing the same for mine. Unfortunately, the ZHP uses glass fogs. At $100 a pop, they aren't cheap. I was thinking of doing this idea:
http://www.autogeekonline.net/forum/...t-restore.html
The results are impressive.
Old 11-27-2011, 11:26 PM   #19
BeMyWhip
I think my fogs were glass as well. Actually the system worked better on the fogs than on the lenses.
Always Mod!!!
Old 07-15-2012, 01:47 AM   #20
BM-MAN
My Ride: Hot 3 coupe
Send a message via MSN to BM-MAN
Man, foglights after pic is VERY impressive. I am going to tackle this ASAP!!! I was 2 seconds away from ordering a new set since mine are so pitted and faded. Great job!
BM-MAN is offline   Reply With Quote
