Sponsored by The Tire Rack
Old 11-28-2011, 05:05 PM   #1
SF323Ci
My Ride: 2000 323Ci
Mismatched Tires - Better tires in Front or Back?
I have 4 crappy Capitol 225/45/17's at the moment; they were new when I bought the car 15k miles ago. The fronts are fine, the rears are probably past 50% and wearing unevenly.
As of last night, one of the rears also has a nice big screw dead center in the tread. I think one of my neighbors has it in for me. I've already spent my tire budget for this quarter replacing the rear on my motorbike (did I mention someone is out to get me?).
I can get a really good deal on a pair of Pirelli P-ZERO NERO's, so I think I'm going to go ahead and replace just the rear tires. I have enough grip for the kind of driving I do already (never broken traction without really trying to), and I am assuming the Pirelli's will be better than what I have. I know it's less than ideal to mismatch tires, but I'll even it out a few months down the line.
My question is - do I put the better tires up front or in the back? I'm wondering if front makes more sense, so that if I ever do lose traction unexpectedly it will be in the back, giving me more control? Losing the wheels I steer/brake with while the driven wheels are still gripping seems like a scarier prospect than having the back end potentially slide around.
SF323Ci is offline   Reply With Quote
Old 11-28-2011, 09:40 PM   #2
Minnoe07
My Ride: 2004 BMW 330Ci
Better tires in the front. Having said that, if you're short on cash, why don't you just patch the tire and call it a day? And get an alignment and rotate tires if they are wearing unevenly.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 11-28-2011, 09:45 PM   #3
Big Geek
My Ride: 2001 325i
Better tires in back. You don't want the ass end to come out in a turn. Ask your local tire shop. They will tell you the same. Or get matching tires ASAP.
Big Geek is offline   Reply With Quote
Old 11-28-2011, 09:49 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
i say better tires in the front. if the back slides you can save it usually, if the front slides, usually its followed by bad crushing noises.
Plus they do the stopping and the steering.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 11-28-2011, 10:49 PM   #5
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Better tires in the front as long as you know how to control oversteer
Chris
dreamdrivedrift is online now   Reply With Quote
Old 11-29-2011, 09:06 AM   #6
JohnBlaze
My Ride: Black Sunshine
from a safety perspective, you want the good tires in back. Because, if you brake hard in the rain, you'll hydroplane and the rear will come around on you.
In ideal conditions though, bald in back
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 11-29-2011, 12:44 PM   #7
SF323Ci
My Ride: 2000 323Ci
It seems like on the rear is the way to go (about a 50/50 split here and unanimous 'rear' from tire shops and the car talk guys).
I'm guessing if I keep what I have in front I'll be no more likely to lose traction up front if I keep driving the way I normally drive, but if I run less grippy tires in the rear I run the risk of the back wheels trying to overtake the front under normal conditions because of the mismatched traction rather than the severity of the turn / braking event - and a spin is not something I can get out of easily. Sound plausible?
Old 11-29-2011, 01:00 PM   #8
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
New/better tires on the rear.
http://www.tirerack.com/a.jsp?a=BN4&....jsp&techid=52
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 11-29-2011, 01:16 PM   #9
Snik
Snik's Avatar
Originally Posted by Gary@Tirerack View Post
wow, interesting read Gary. if it were anyone else i'd say w/e, but you guys are the SME. Thanks for sharing.
Old 11-30-2011, 04:10 PM   #10
SF323Ci
My Ride: 2000 323Ci
Rear it is then.
Thanks guys.
Old 12-03-2011, 01:13 PM   #11
steifan
My Ride: 325i '06, 323 Ci '00
This shows the difference with better and worse new tires fitted to the front respectively to the rear.
In Swedish, but 0:37-> shows test winning tires on the rear
and 1:04-> test losing tires on the rear
Same tread depth, different brands.
And one point is that cars are better built for frontal collision than from the sides or rear so you'd rather crash with the front first.
steifan is offline   Reply With Quote
Old 12-03-2011, 04:20 PM   #12
2003 325i
My Ride: '03 Orient Blue 325i
Better in the rear esp if over 4/32" tread difference, if not then can be rotated to even out wear (better on front for front wheel drive vehicles). If you start to hydroplane with bad tires in the front you'll feel it in the steering wheel and you can slow your ass down. If you start to hydroplane with bad ones in the rear... it may be too late.
Old 12-03-2011, 06:45 PM   #13
jasonbimmer
My Ride: 2001 BMW 330xi
better in the front, at least you will be able to slow down in time.
although I dont think it will snow that heavily in SF, it just snowed in Nebraska and my almost bald front tires are making stopping very difficult.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-13-2011, 05:58 PM   #14
SF323Ci
My Ride: 2000 323Ci
My car sees rain at most 15 days a year, and for most of those it's under cover, I don't think it's ever even seen snow.
Old 12-13-2011, 06:24 PM   #15
2003 325i
Looks like mamma's wrong again.
- Colonel Sanders
Old 04-03-2012, 02:42 PM   #16
SF323Ci
My Ride: 2000 323Ci
Ran mismatched for a couple of months, then got 4 new 225/45/R17 Yokohama Avid Envigors. So far so good - they're quiet and grippy, and had the highest tread wear rating of anything on offer. Should be just fine for my style of driving (90% sedate, 10% 'spirited').
