Cold Start Misfire Problem [Worse in Cold Weather] - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-01-2011, 01:15 PM   #1
hontoir
My Ride: 320Ci
Evening all,
I am a member on bimmerforums also and was just looking for a larger variety of opinions.
Scenario
E46 320Ci M54 - Starting from cold
Can feel car vibrating (misfiring) at initial idle of 1k, and this normally goes away once the idle drops down to 700rpm.
If the misfire does not go away then turning off and restarting cures this.
Fault Code
Misfire Cylinder 5. Although does produce the occasional Cylinder 2.
Diagnostics so far
Spark plugs renewed
Ignition coils swapped
Fuel injectors swapped
Rocker cover gasket replaced
Block tester completed (all ok)
Compression test completed (good results)
ICV cleaned
DISA cleaned
Intake hoses checked for leaks (all ok)
Indy thinks it is either
Hydraulic valve lifter problem, although I am not sure how this ties in with the compression test being fine.
Or
A problem with the control signal from the ECU to either coil or injector for cylinder 5.
Using INPA the smooth running for cylinder 5 goes off the scale.
Any input is most welcome as I don't want to keep forking out money for nothing.
hontoir is offline   Reply With Quote
Old 12-01-2011, 01:40 PM   #2
lsteg
My Ride: 2001 330ci
Vanos seals are bad
lsteg is offline   Reply With Quote
Old 12-01-2011, 02:25 PM   #3
hontoir
My Ride: 320Ci
Why would that only affect cylinder 5?
Old 12-01-2011, 02:39 PM   #4
lsteg
My Ride: 2001 330ci
ok, after some re-reading and research,
are you hearing any noises coming from the engine bay?
is it still throwing codes after you fixed all of those items?
i'd do a smoke test to completely rule out a vacuum leak
Old 12-01-2011, 02:41 PM   #5
hontoir
My Ride: 320Ci
The indy reports a very quiet ticking from the top end. (Although some say this is normal)
Yes the codes are still being sporadically thrown.
And a vacuum leak would cause issues with all cylinders.
Old 12-01-2011, 02:51 PM   #6
lsteg
My Ride: 2001 330ci
not necessarily, I still suggest doing a smoke test to completely rule out a leak as the cause of the issue. visually inspecting is ok, but these things are easy to miss and the smoke test may say you a lot of time and headache.
Old 12-01-2011, 03:10 PM   #7
hontoir
My Ride: 320Ci
If there were a vacuum leak, would this not cause problems both cold and hot? As this is only on a cold engine, and it gets worse when the weather is colder.
Old 12-01-2011, 03:13 PM   #8
lsteg
My Ride: 2001 330ci
cold weather might have actually caused the vacuum leak. parts become cold and brittle and then eventually crack.
most issues that deal with rough idle and cold weather tend to point to the vanos though
Old 12-01-2011, 03:22 PM   #9
hontoir
My Ride: 320Ci
Is there anyway of testing the vanos?
Old 12-01-2011, 03:24 PM   #10
lsteg
My Ride: 2001 330ci
not that I'm aware of. It's just one of those parts that you look in to when you get certain symptoms. I haven't rebuilt mine yet but from reading up on it and looking at the DIY's it doesn't seem that bad. All you do is just take it apart and replace the rubber seals (more or less). Do some research, there's a bunch of VANOS rebuild threads out there.
Old 12-01-2011, 04:30 PM   #11
hontoir
My Ride: 320Ci
I would imagine that the oil separator is original, car has only done 54k. However, I do not want to fork out big money on items that MAY not be the cause.
Old 12-01-2011, 04:54 PM   #12
hontoir
My Ride: 320Ci
I have already had it out to clean it, it is fitted with the OEM orange seal which looked to be in good condition.
Also, how would I go about checking the operation of the oil separator (CCV)?
Old 01-19-2012, 10:11 PM   #13
DJ RaMiN
My Ride: 02 325I,03 M3
so did you fix the problem? if yes what was the problem?
DJ RaMiN is offline   Reply With Quote
Old 01-20-2012, 03:12 AM   #14
hontoir
My Ride: 320Ci
It is going in to have the lifters changed on cylinder 5 next weds.
Old 01-20-2012, 03:53 AM   #15
Dippinwandy
My Ride: 325i
this sounds like the exact same problem im having.
Dippinwandy is offline   Reply With Quote
Old 01-20-2012, 05:39 AM   #16
Schnake
My Ride: 325ci
Let us know how you go with the lifters. I have read countless threads on the issue and everyone has their opinions but there is never any conclusion to advise the real issue.
I have been advised that the lifters are a common cause too.
Good Luck
Schnake is offline   Reply With Quote
Old 01-20-2012, 05:45 AM   #17
jfoj
My Ride: 330CiC, M5, X5, E93
Trust me on this, I see all kinds of tail chasing and big expenses on lot of parts replacements. Skip the VANOS for now, my be an issue, BUT, please read my original post and do the following before you go down the VANOS road.
1. Replace the DISA O-ring with the ebay $12 part. You want a silicon based part, but rubber will work for a while, but the silicon is more flexible. The DISA O-ring is a major problem due to the the size of the opening and the original silicon getting hard and not expanding and contracting causing cold vacuum leaks. The DISA should not pull out easily when you go to remove it, it should require a good pull to remove, otherwise the O-ring is bad. The DISA usually caused more misfires in the center cylinders from what I have seen.
2. Replace the lower CCV oil drain back to the dipstick tube. This is either cracked or oil soaked and close to breaking or cracking.
I would not spend any more money on other items until at least these 2 items are REPLACED, not just inspected.
Again, this may not solve your problem, but 2 items are VERY common and often overlooked.
http://forum.e46fanatics.com/showthr...616&highlight=
Old 01-20-2012, 09:38 AM   #18
hontoir
My Ride: 320Ci
I am having a smoke test done prior to having the lifters changed. This will identify any issues with the intake including the DISA seal.
Old 01-20-2012, 05:40 PM   #19
jfoj
DISA may not be picked up in a smoke test, partly a function of temperature as the DISA contracts and expands quite a bit.
Old 01-20-2012, 05:44 PM   #20
hontoir
My Ride: 320Ci
How would the DISA cause a misfire on ONLY ONE cylinder?
