Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 12-01-2011, 10:05 PM   #21
A4RingedONE8T
My Ride: Turbo ///M Roadster
Originally Posted by bluejeansonfire View Post
I think that's the first equal-length twin scroll manifold tig'd cast stainless.... billetted from a solid block of awesome. that collector is art. That whole thing is art. Shawn, I cannot contain how impressed I am. It even looks relatively installable. The wastegate pipe angle looks like it might have a tiny bit of creep, but I'm sure that it has so much wastegate, and it's not like that angle is that bad anyway. Your work has only gotten more impressive.
I heart the high-sitting bottom-mount. Great drain characteristics. I wonder if that angle will create any oil drain/seal challenges on the exhaust side, doubt it though.
In for motormount. and wg tie-ins or dumps
I love this manifold, I've been starting at pics of it since I left the shop. I can't explain what I think about it, can't believe I made it honestly. I just got rolling with fab work not so long ago it seems. I put everything I have into each and every one of these setups. I build them as if they were my own, and if I had to look at them everyday, hopefully they fill the shoes of the owner and they love them as much as I do! I appreciate your comments, gotta get up your way again sometime soon! Take care, hope the car is running well!
Originally Posted by 02black330ci View Post
WOW! Freaking beautiful, any way to make this work with our E46 M3s?
Send us the car, I can work my magic in those frame rails as well
Originally Posted by Estoril-E46 View Post
Ugh, topmount in the freespace would have been so much cooler....
You don't have to argue with me about top mounts, it's a win win regardless. I've stared at this turbo and engine bay for over a month now while we were waiting for other pieces to arrive to get started. The back housing, 1.06, is gigantic on this thing, even though 35R. It's big in the wrong place. Fitting the hotside crams the compressor up against the rad support, and the headlight is right there with no room around it for pipes. I would have loved for it to be up top. This is the best compromise though honestly. It's still very visible, as well as the manifold. On a top mount setup like the one in my Z3M, the downpipe blocks the whole manifold, so it's a different look for sure. This is also my first bottom mount setup I've done EVER! Me =
Should have no oil drain issues as it is a very very high bottom mount, will fit a full 4' intake as well placing a filter in front of the shock tower, a/c compressor isn't even near, some custom a/c lines and the car will be bling under the hood, beastly in power and spool, and have all the likings of a stock car
Want some top mount love, check this out, just finished this up last week, I'll have a thread for it up very soon as well
Thank you everyone for your comments, I greatly appreciate each and every one!
-Shawn-
A4RingedONE8T is offline   Reply With Quote
Old 12-01-2011, 10:12 PM   #22
Estoril-E46
My Ride: M3
Naw, I was talking about behind the strut actually, wanted to see one there, you could fit 2 turbos there, haha. The hardest part would be room to get the exhaust back down, but definitely doable.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 12-01-2011, 10:17 PM   #23
A4RingedONE8T
Doable and wise two very different things. I crammed my 74mm on the top in my car, way less space. Was it the wisest choice, definitely not, was it doable, everyone told me it wasn't. I'd say it worked. I'd love to see a turbo back there, let's see it
Old 12-02-2011, 12:18 AM   #24
mtran850
My Ride: C6 Z06
Originally Posted by AAblown View Post
My, your banned from here till you buy another BMW...lol j/k
Nice work Shawn
Z4M Turbo w/ the new AEM Infinity 10
mtran850 is offline   Reply With Quote
Old 12-02-2011, 12:35 AM   #25
Andy2108
My Ride: SpecE46 & E46 M3
Old 12-02-2011, 02:29 AM   #26
basar13
My Ride: Z4M, R8, 525xd, STI
basar13 is offline   Reply With Quote
Old 12-02-2011, 02:42 AM   #27
basar13
Looks like there is space for a bigger turbo ? Did you tried any ?
Old 12-02-2011, 05:07 AM   #28
Beedub
My Ride: bmw z4m vt2-525
yessss it about time the z4m got some tuner work!!! Z4m FTMFW!!!!
bmw z4m. vt2-525.. 8psi pulley..
Beedub is offline   Reply With Quote
Old 12-02-2011, 07:21 AM   #29
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
4" intake is go, Cap'n
Aside from the wider framerails (there's too much room there for it not to be wider).... it seems like the tilt sort of helps getting around the AC compressor and also downpipe. The flareout from 3" up can be done instantly without any interference or dealing with much bend... this gets more win by the moment.
big power. instaboost. This thing will probably spool kunder 3krpm. Clearly, you're cheating.
EDIT: just read exhaust plans..ok... you could go 4", this is ready and imo waiting for a shawn can.
PRI?
EDIT:
wut is going on with those strut towers!?
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 12-02-2011, 08:03 AM   #30
A4RingedONE8T
PRI?
EDIT:
The angle of the turbo makes everything much everything pretty smooth. Only tight connection to the turbo is going to be the turbo outlet, but with a welded 90* on the compressor, there should be no problems!
I would love to put a 4" turbo back single sided exhaust on it, not what the customer wants though. I think I'm the only one odd enough to do that
I'll be at PRI today, and the strut towers on the M3 were flattened a little to fit the vents of the VIS carbon fiber hood, havent gotten a chance to add some filler and paint lol
Old 12-02-2011, 04:54 PM   #31
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Can't wait to see this thing all polished up!!!!
Old 12-03-2011, 03:53 AM   #32
basar13
Nice manifold i hope Trevor lets them make one for me
Old 12-03-2011, 08:54 AM   #33
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I can't wait to go for a rip in this thing!! Gonna have to invest in a hans device with Trevor at the wheel
Old 12-03-2011, 11:09 AM   #34
forcefedvw
My Ride: 03' Z4 '00 VW
Boostlogic style
more like how we do it on diesels.
Innovative Performance
http://www.facebook.com/pages/Innova...609652?sk=info
2JZ-GTE Conversions & GM LS-Engine Conversions
forcefedvw is offline   Reply With Quote
Old 12-03-2011, 11:16 AM   #35
forcefedvw
-Shawn-
This Reminds me of Dragans e36 m3
98 M50/S52 GT35R Tec3R standalone 680whp 610wtrq
Old 12-07-2011, 04:43 PM   #36
Beedub
hi their OP , any info on the fuel pump setup the z4m uses?? HPF say its different to the e46 m3, can you shed any light on how your planing to fuel this beast..... i did ask earlier in the thread but..... ermm i guess you missed it ;-)
Old 12-07-2011, 05:33 PM   #37
lutzperformance
Lutz Performance-FL BMW F/I
My Ride: 1995 BMW M3, 04 Z06
Send a message via AIM to lutzperformance
We are building our own fuel setup for this car as it will be using E85!
More details to come, fuel pumps and injectors are listed in the original post!
Thanks!
lutzperformance is offline   Reply With Quote
Old 12-15-2011, 08:10 PM   #38
A4RingedONE8T
Sorry for the lack of updates, been a busy two weeks at the shop. Did get a chance this week to spend about 15 hours welding up the manifold
Welded in and out
Some more of the bling
Still a big pile of materials!
Old 12-15-2011, 08:25 PM   #39
tchev007
My Ride: Z4M Roadster
Looks phenominal !!!
...and incredibly heavy duty to withstand my abuse!
Thanks for all the great work Shawn!!
tchev007 is offline   Reply With Quote
Old 12-15-2011, 09:24 PM   #40
Commanderwiggin
Must...not...fap...
