E46 Xi Forum
Old 12-04-2011, 06:34 PM   #1
jasonbimmer
My Ride: 2001 BMW 330xi
F/R diffs capacity?
I was changing diff fluids today thought the rear diff takes 2 qts and front takes 0.75qts.
the actual figure turned out rear diff is about 1.2 qts and front is close to 0.8 qt.
did I miss something?
and yes I know how to change fluids, I pumped and pumped till fluid came out like stream. I even waited 5 min then double checked it again.
I was also amazed how low the old fluid was, nothing came out when I pulled the fill plug.
FYI, if any of you guys getting chattering noise at the front near the diff at 35mph, check your diff fluid, it might be low.
I replaced the axle twice and lost some amount of fluid and it was making a chatter noise at 35mph.
also the front diff fluid gets worn out much quicker than the back due to engine heat.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-04-2011, 08:35 PM   #2
TiAgXi
My Ride: e46xi, e46m
Was the car level when you filled the rear? I'm surprised that none came out when you opened'er up.
TiAgXi is offline   Reply With Quote
Old 12-04-2011, 09:18 PM   #3
jasonbimmer
no no no.
none came out when I opened the FILL plug (low level).
yes the car was level.
10 yo and 116k miles I am not surprised the level got low, no leak tho.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 12-04-2011, 10:37 PM   #4
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
you probably need front diff seals
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 12-04-2011, 10:40 PM   #5
jasonbimmer
like I said no leaks.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 12-05-2011, 02:05 PM   #6
GCoop
My Ride: '04 325xi
Mine was the same as yours when I did the fluids for the first time @ 60k. since then I have found many others that had similar experiences with the original fluid fill level so its probably normal. I wouldnt be too concerned.
GCoop is offline   Reply With Quote
Old 12-05-2011, 02:35 PM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
My notes say the front differential takes 1.3 pints and the rear takes 2.6 pints.
ECS Tuning
Old 12-05-2011, 03:07 PM   #8
jasonbimmer
ECS Tuning
once again, great info from ECS. so I was about right.
I guess the 2qt rear is for RWD version since they have much beefier rear diff.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 12-06-2011, 08:10 AM   #9
Kubica
My Ride: 2003 325xi
^No rear diff is the same as rwd. So is the fluid capacity.
Old 12-06-2011, 10:34 AM   #10
jasonbimmer
thats interesting.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 12-06-2011, 10:48 AM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Correct the E46 (used an 01 for my numbers) RWD uses 2.6 pints in the rear diff.
ECS Tuning
Old 12-06-2011, 06:37 PM   #12
My325XI
My Ride: 03 325XI Sprt Prem
Per::
http://www.xiftw.com/?page_id=19
Component OEM Royal Purple Redline QTY (Qts)
MAN Trans MTF-LT-2 Synchromax D4-ATF 1.3
AUTO Trans
Transfer Case Synchromax D4-ATF 0.2
Front Diff Max-Gear (75W90) 75W90 Gear oil .8
Rear Diff Max-Gear (75W90) 75W90 Gear oil 1.1
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
