Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Thread Tools Search this Thread Rating: Thread Rating: 83 votes, 4.76 average. Display Modes
Old 12-06-2011, 12:52 AM   #81
m3unit07
My Ride: 1999 328i
whoaaaa dude good luck with this, can't wait to see the final product
m3unit07 is offline   Reply With Quote
Old 12-06-2011, 01:00 AM   #82
patdeezy
My Ride: a grey e46 sedan
Send a message via AIM to patdeezy
-m330-
EUROPROJEKTZ
REALIE CLUB 2007 - I'M KEEPIN IT REAL!
SPONSORED BY
|SGC Godfather|
KOBE in 2012
patdeezy is offline   Reply With Quote
Old 12-06-2011, 01:04 AM   #83
Osprey
My Ride: 2002 BMW 330i
Wow, that is some incredibly impressive stuff! I am going to have to take some time off work and come to one of your Friday Night Meets to see this beast when it is completed. Best of luck with the project!
Current: Alpine White 2002 330i
Past: Titanium Silver 2004 325iT--ZPP, ZCW, 5 Speed
Red 1997 Volvo 850 GLT (low pressure turbo FTW!)
Osprey is offline   Reply With Quote
Old 12-06-2011, 05:56 AM   #84
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
you moved just for the swap?!
i'm extremely jealous of this project, but more of your knowledge and skills. how did you learn to do work like this? any schooling?
my goal one day is to do a ls swap into an rx7.
Old 12-06-2011, 09:18 AM   #85
BDUB328I
My Ride: bmw 328i S54 sedan (
im doing a sedan swap on my 328i right now, keep in contact with me so we can bounce questions back and forth....
Are you going to wire in the EKP relay so all that m3 fuel system is worth swaping? also what about the, Heater valve wiring?
Awesome job so far, your at about the same stage as me so it will be interesting to see what route you take, however mine didnt have the m3 rear when i started.
BDUB328I is offline   Reply With Quote
Old 12-06-2011, 09:32 AM   #86
Custom3
My Ride: HellRot 330CI
balls
Old 12-06-2011, 02:42 PM   #87
323ci newbie
My Ride: mkodama
Originally Posted by -Jay- View Post
it took him over 2 years to get this far, so my guess would be another 2 years.
seems about right
323ci newbie is offline   Reply With Quote
Old 12-06-2011, 02:54 PM   #88
Oliver.R
My Ride: 2000 328ci
good luck man, hopefully no major snags yet, hope i can see it soon
Oliver.R is offline   Reply With Quote
Old 12-06-2011, 03:32 PM   #89
cyberkaa
My Ride: E46 332i,M3;E30 325i
Thank you all for your kind comments and words of encouragement! I'm sorry I can't respond individually, but I did read all of them.
I will, however, address some of the specific questions people had:
Originally Posted by LeMansteve View Post
Any easier if you are swapping into a car that is already a manual?
A little bit, yes. You don't have to deal with the pedals too much (just need to change clutch master cyl, I think), nor do you need to run that hydraulic pipe under the carpet. A tiny bit of the wiring will also be done already, but you won't be able to reuse some of the steptronic shifter wires that are already in the harness, which are going to come in very handy.
If you have a 6MT 330, you can even run the non-M drive shaft and rear end until it breaks.
Originally Posted by edlvrt View Post
Awesome job. Dumb question, but why didn't you just keep the engine in the white M3?
Originally Posted by lax01 View Post
Let me get this straight, you took two working cars and made one working car?
Is that accurate?
Nope, not accurate. The white M3 is still whole and serving beater duty. Nothing was removed.
Originally Posted by ACS Rob View Post
+1 on the useful post count.
Originally Posted by iansanderson View Post
nice. question, are you going to keep the stock cluster or use the one from the donor M3?
I'm using a matched DME, EWS, LCM, and IKE set from an M3. The IKE will be wired up to make the oil temp gauge work.
Originally Posted by Mike @ TheBMWPartStore View Post
Looks great Kalim!! Really looking forward to the future progress.
Thanks, Mike! Looking forward to getting those last few parts.
"Beater" M3 had a blown engine and poorly repaired after an accident(s). Good engine went in there to act as a "test" bed, but in the time between that and the creation of this thread, Kalim has managed to hoard more S54s so I lost track of which engine is actually going where.
Originally Posted by Drewdown View Post
hold on... let's see if I can get this right. The first motor that came from an e30 swap project was sold. The second motor was going to go into the sedan, but now he's keeping it in the m3 with a messed up chassis I think the third motor is the one going in the sedan and the fourth s54 was sold. I think that's it, although I might have mixed up the last two
Haha, I have been through a few S54s so let me see if I can clear this up.
S54 #1 was bought along with all the swap parts
S54 #2 was bought as a no frills long block (newer)
S54 #1 was sold
S54 #3 was removed from the white M3 (blown motor)
S54 #2 was put into the white M3 (beater status)
S54 #4 was bought (newer still)
S54 #3 was torn down
S54 #4 is going into the sedan
Originally Posted by M_Truong View Post
So close yet so far! I still need to give you the pics I have of you guys pulling the motor out.
Yes, please! Send me pics and I'll update the thread.
Originally Posted by flashtwosix View Post
anyhow, to the OP. great work. can't wait to see the end result.
where did you get the custom drive shaft?
how much is the labor on getting the drive shaft shorten and balanced?
btw..is there any other other solution other than getting it shorten (ie. Z4M)?
Thanks! I don't have the name of the shop that cut and balanced it, but it was a place on the east coast that my shop subcontracted when I had the rear end installed. (Decided this was something I'd rather guide the shop guys through rather than do on my back in a carport in winter, haha). I do remember that it took a while to find a shop with the capability to work on BMW shafts, though. I gave them an M3 drive shaft to work with so they took a little off the front section and welded it back together. The cost was $300+OEM M3 shaft, including shipping both ways.
Believe me, we tried quite a few different ideas and this was a big reason why the rear end swap took 5 weeks instead of 1. I wasn't sure if the Z4M center support bearing mounted up to the chassis in the same spot, so I have no info on that. The parts diagrams list overall length instead of sectional length, so you have to do some math to figure out front vs. rear section length. E.g. for E46s, you can take non-M auto, non-M 6MT, and M3 6MT and work down the line to figure out how much shorter the shaft gets on either end as you add the longer trans and the longer diff. Then, you have to make sure the input and output flanges match.
In any case, mine will be up for sale once the swap is done!
Originally Posted by kwlaznkid View Post
aw **** i didn't make first page... and.. all i have to say is i see my jack in this pic, without my jack none of this would be possible
[IMGhttp://i457.photobucket.com/albums/qq292/cyberkaa/garagewerke/S54%20Swap/IMG_2888.jpg[/IMG]
but good work bro, can't wait to see the end result, any estimate on date of completion?
JT Jr. is an invaluable member of my garage staff.
Should be about two more weekends to get the car started, I think.
Well, I wouldn't say just for the swap, but being able to work on cars in the garage was a huge factor, haha.
I'm self-taught in automotive work as a hobby. A degree in Electrical & Computer Engineering also comes in handy from time to time.
Awesome. Good luck on your project, dude!
I'm going from MS45 to MSS54, so my wiring is just slightly easier.
Yes, I'm doing the EKP relay retrofit. It's kinda interesting that non-US models have the same relay setup as my non-M, though.
Keeping the heater valve wiring the same, but I'm planning on adding the auxiliary heater pump to IHKA wiring.
I'm in the middle of making a wiring plan, which I should be implementing over the next couple of nights. Stay tuned!
-Kalim
(klx photo studio)
Old 12-06-2011, 04:35 PM   #90
albeee
My Ride: MKVII GTI
Oh come on, Kalim, you can afford to a little bit before you hit 100k. This car is close to being done.
Originally Posted by VALMONT View Post
stancewerks is for dudes who pick up dudes for a little stretch and poke.
albeee is offline   Reply With Quote
Old 12-06-2011, 04:40 PM   #91
albeee
My Ride: MKVII GTI
S54 #1 was sold
S54 #2 was put into the white M3 (beater status) and will be swapped into another beater car (possibly albeee's) once sedan swap is finished
Mwa ha ha.
Old 12-06-2011, 06:14 PM   #92
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Mwa ha ha.
a fit with an s54? ...sure
lets just build a trailer and throw it on my bicycle... it will do just about as much good
Drew@Swift Motorworks is offline   Reply With Quote
Old 12-06-2011, 06:18 PM   #93
albeee
My Ride: MKVII GTI
Not with your bodywork skills we won't.
Old 12-07-2011, 11:57 AM   #94
BDUB328I
the reason i asked about the heater control valve is becasue the one from my m3 has two seperate connections a total of 4 wires going to it, the 328i version has one conection with 2 wires going to it. Interested in knowing some more info on your plan... ill stay tuned.
Old 12-07-2011, 11:59 AM   #95
Oliver.R
My Ride: 2000 328ci
did someone say bodywork?
Old 12-07-2011, 11:49 PM   #96
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
now i'm waiting for kalim to make M3 fenders and quad exhaust too
-Derek
Stoptech Front BBK|M3 LSD|GC Coilovers w/ Swift Springs|UUC TSE3 Exhaust|
My Build Thread
crazyxzer0 is offline   Reply With Quote
Old 12-09-2011, 07:30 AM   #97
M_Truong
My Ride: 2008 335i
Just thought I'd come check-in.
M_Truong is offline   Reply With Quote
Old 12-09-2011, 08:03 AM   #98
Obioban
My Ride: 05 M3, 01 M5, M3iT
Send a message via AIM to Obioban
Awesome project, can't wait for more updates.
I'm working up to doing a wagon for myself
-Ian
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, Wife's 6mt NA RWD e91, 04 M3 wagon
Past cars: 04 M3, 96 M3, S50B32 e36 M3 CM race car
"People do not see good design." -- Claus Luthe, BMW chief designer e30-e39
Obioban is offline   Reply With Quote
Old 12-09-2011, 08:45 AM   #99
S15NOB
My Ride: E46 330i
subscribed.
-tip.
S15NOB is offline   Reply With Quote
Old 12-11-2011, 05:16 AM   #100
cyberkaa
Mwa ha ha.
I don't it'll fit in the Fit.
Correct, but it's not just a valve; there are two separate units mounted in the same bracket. The valve part is exactly the same as the non-M version, but for the other unit (auxiliary water pump), you need another 2-pin connector. WDS has the wiring you need. You need to run one wire to IHKA and the other to ground, IIRC.
I don't know, maybe, haha. Still tossing around a couple of ideas.
Yo, Marvin! Come by later today (Sunday) if you're not busy.
Thanks, Ian.
I've been thinking the same thing.
-Kalim
(klx photo studio)
