Old 05-03-2013, 06:28 PM   #741
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Originally Posted by 323tom View Post
Another week no dyno.
Feel like this! SP...no...
Old 05-03-2013, 07:33 PM   #742
SlideFox
My Ride: A Bucket w/ 4-Wheels
What's the hold up?
SlideFox is offline   Reply With Quote
Old 05-03-2013, 10:11 PM   #743
xixixi
Banned User
My Ride: 01 330x-xi
Bottle neck? Not seeing the numbers they are after? Car is broke? Shop is busy, waiting on parts? Lots of things it could be.
Old 05-04-2013, 12:01 AM   #744
323tom
My Ride: 2 turbo e46's
Dyno has been busy, hopefully early next week I'm going insane lol
323tom is offline   Reply With Quote
Old 05-04-2013, 12:04 AM   #745
xixixi
Banned User
My Ride: 01 330x-xi
Need to get laid..
Old 05-04-2013, 12:22 AM   #746
Commanderwiggin
Originally Posted by xixixi View Post
Need to get laid..
The real reason:
Old 05-04-2013, 02:56 AM   #747
Twin_Turbo_S54
My Ride: M3
Tom,
I am positive that SP will hit the numbers you want, soon.
I have pushed my M3 on the dyno Dynamics back in 2008-2009. At least 5000 dyno runs. Maybe 10.000 dyno runs. So many...
On each dyno day I had 50 runs.
After all those dyno runs, I put the M3 on the road and this is where real life began.
On Dynamics I saw 997 whp thats almost 1176 on dyno jet.
Do you know what happened?
I suffered due to traction issues, cause dyno does not tell you if you have decent traction or not.
I suffered due to a poorly desinged power band. Twin 68 mm chargers spooling late @ 6800 rpm....
I sold my dyno Dynamics, as it was useless. A 1200 whp M3 does not mean that it will be fast.
Then I road tested till I hit 4,23 s 60-130 mph. I used the real road to test.
To make the story short, dont focus on dyno numbers. A 700 whp M3 with proper power band and decent traction will destroy a 1000 whp M3 easily. Its all about the power bands's overall efficiency and traction.
Dont rely/focus on dyno results. Remember there are at least 10 stage 3 & 4 HPF M3s and none of them are fast. They are what we call "dyno queens". Just numbers and no good times.
Have you seen any stage 3 & 4 M3s with sub 5 seconds 60-130 times? Nope, cause they just make the power on dyno.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 05-04-2013, 10:28 AM   #748
323tom
Don't you worry Mert I will do some 60-130 times just for you! Also most m3 owners are not wide body like me and able to stuff 18x12 rims with 335 r888s in the back, the pro efi traction control really helps to I was impressed last year and also the nitrous will help bring the 7675 to life at lower rpms!
Old 05-04-2013, 12:36 PM   #749
Twin_Turbo_S54
My Ride: M3
Just do it Tom, put the beast on the road, forget about dyno figures.
Even if you could put a set of 385 tires, there is none I am just trying to give an example, you cant have enough traction with 385 tires unless the complete vehicle has traction.
Old 05-04-2013, 01:34 PM   #750
323tom
I agree Mert, last year I only went up to Iboost 3 of 5 with 80 % ethanol content which I believe was around 26-28 psi and 800whp+ and I can tell you I was frightened when I heard the pro efi traction control go off for this first time, it felt insane! I never tried Iboost 5 as the vibrations my car was making was also scary, I believe it was the 1 pc drive shaft that I had removed now but SP says there is still vibrations but not sure if as bad as before.. Are you running solid motor/tranny mounts?
Old 05-04-2013, 02:02 PM   #751
Cipri
My Ride: E46 M3 2002
New SP Project
Tom, you will not have vibration problems at high speeds because of the solid mounts, i have HPF engine+trans and Rogue diff - all solid aluminum mounts, the only vibrations which are disturbing me are at idle, at high speed almost no vibrations.
Cipri is offline   Reply With Quote
Old 05-04-2013, 02:03 PM   #752
Twin_Turbo_S54
My Ride: M3
I do run stock mounts all over.
I used to have 1 piece carbon sheety meety pitty shaft, which failed 2 times.
I ended up with oem BMW shaft.
Although it failed, it did not make any vibs.
My 3 M3s do not vibrate.
What may vibrate on your beast:
- check the transmission, you may have damaged the tranny and it may vib. It may be the 1st to check.
- guibo, cheap product, test a new guibo.
- vibration damper, test a new damper.
- all pulleys, ac pulley, coolant pump pulley, steering pulley.
- flywheel, get it balanced.
Does the vibration happen at each gear between a certain rpm range_?
Have you tried driving @ 2nd gear @ 7000 rpm and is there any vibs or does it vibrate @ over a certain road speed?
Havee you checked your Wheel bearings?
Old 05-04-2013, 03:49 PM   #753
323tom
Yes I know I have been in a e36 m3 with solid motor and Tranny mounts aswell as a type r integra and its mainly low rpm/idle vibrations..I knew it wasn't the motor mounts but Larry thinks it is... Now that the 1 of drive shaft has been removed I bet it's just low rpm/idle vibrations... If it still vibrates same as high speeds It may any of the things Mert has said but that's how I recieved my car back last year and definitely not how I brought I here so it has o be something that was installed or something broke from dyno runs... I am really hoping it was just the 1 pc drive shaft and the vibrations are at minimal but I won't know until I pick my car up, wish I was closer than 9 hours away from my car lol
Old 05-04-2013, 04:49 PM   #754
Commanderwiggin
Flights are cheap in comparison to your build cost...time for a visit on your investment before you commit to a return.
Old 05-04-2013, 04:54 PM   #755
Sound Performance
Past Site Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
Sorry guys, I was out of town for 2 weeks, one doing training and one helping my mother. Then when I get back my cousin unexpectedly dies. Needless to say I am quite a bit behind at SP as I am the one that does all of the electronics installs and tuning. I think there are 6 cars there waiting to be tuned/dynoed and 4 more waiting for ProEFI systems. Then there are over 20 more cars on a waiting list!!
Sound Performance is offline   Reply With Quote
Old 05-08-2013, 01:23 PM   #756
323tom
I have made a decision, If the car is not done by end of this week I will have FMU in Chicago pick the car up. I really did not want it to come down to this but I can't stand being promised/told "by the end of the week" any more. I have been more than patient and my payments have never been a issue. Hope SP finishes the beast off by the end of week but whatever happens is fine with me.
Old 05-10-2013, 05:52 PM   #757
E85head
My Ride: E46 M3
Any updates?
E85head is offline   Reply With Quote
Old 05-10-2013, 07:01 PM   #758
323tom
They have a bmw tech coming tomorrow as the car is throwing a bunch of vanos codes... They have till the end of Monday or Tuesday an exotic car transport company will be picking the car up and bringing it to Alpha at Inducion Performace which is another amazing pro efi tuner... I would really love for SP to pull it together last minute but what ever happens is fine with me.
Originally Posted by E85head View Post
Any updates?
Old 05-10-2013, 08:50 PM   #759
M3PTGSC
My Ride: M3
Induction performance in FL? Why not ship it to Jason to AZ?
09 SL63 AMG Designo,pano and whole nine yards lol
07 S550 P2 4matic-gone
03-M3-6766 DBB..Tubular manifold...
97-M3-
95-M3 SC stage 2-Widebody...
08 Gix 1k 08 ZX10R
M3PTGSC is offline   Reply With Quote
Old 05-10-2013, 09:08 PM   #760
E85head
My Ride: E46 M3
Hope your car hits 1000 with e85 only, soon!
