Old 05-12-2013, 10:54 AM   #781
323tom
My Ride: 2 turbo e46's
Perfect, I will order the seal kit with 24 hour express from Raj tomorrow
Originally Posted by MisterM View Post
The beisan seal kit is excellent. Highly recommend and a breeze to install with the excellent DIY procedure Raj provided.
Only fancy tool you need is a proper bench vise.
323tom is offline   Reply With Quote
Old 05-12-2013, 11:05 AM   #782
BrokenM3
My Ride: E46 Coupe
Originally Posted by Commanderwiggin View Post
Could this be broken tabs for the exhaust hub?
No, the tabs on the car look good
BrokenM3 is offline   Reply With Quote
Old 05-12-2013, 11:22 AM   #783
323tom
Nice assuming you were there with Nikolai? Thx!
Old 05-12-2013, 01:14 PM   #784
MisterM
My Ride: 03 M3
Thumbs Up
Make sure you get the double VANOS seal kit ($60), S54 rattle kit ($40), S54/S62 VANOS rattle tool ($30) and pump disc ($150) as well.
If you don't already have a rebuilt solenoid from Raj, that is a no brainer as well.
Ain't double vanos fun SP?
Good luck 323tom. I want to see this beast unleashed.
Mike
MisterM is offline   Reply With Quote
Old 05-12-2013, 02:47 PM   #785
Dreikraft
My Ride: slow m3
sorry tom - i meant bavarian auto recycling. here is there number (916) 635-4269... 6month warranty on used units. fair pricing on s54 too incase anyone was looking for a cheap project build.
dual vanos, single vanos..no matter which m3...its good to have spares!
you'll still need cam locks regardless of the route you choose... best of luck tom.
Dreikraft is offline   Reply With Quote
Old 05-12-2013, 02:59 PM   #786
Commanderwiggin
My Ride: 1000rwhp Turbo M3
No point in buying a used unit...rebuild the old one like he's planning and it'll be better than both!
Old 05-12-2013, 03:49 PM   #787
323tom
Spoke with Raj at beisan, this is what he said...
Here are the causes of vanos codes on the S54.
1. Wrong timing. But someone would have needed to disturb the timing.
2. Failed vanos solenoid coil pack.
3. Sticking vanos solenoid valve body.
4. Broken exhaust hub oil pump driver tab.
The most common cause is a failed solenoid coil pack. This is often
intermittent. So testing it is not effective. We provide a rebuilt solenoid
coil pack that addresses the design problem so the problem doesn't recur.
The solenoid valve body is cleaned during the solenoid coil pack replacement
procedure.
To check the exhaust hub driver tabs you would need to remove the valve
cover.
Old 05-12-2013, 08:26 PM   #788
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
New SP Project
procedure.
cover.
Raj is excellent and is priced fair. He helped me and solved my issues early on with my car. I replaced selinoid pack, and seals as well as valve body. Fixed my Vanos problem.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-13-2013, 08:39 PM   #789
imapimp
My Ride: 2002.5 AV6 6MT 04M3
My guys were just at SP today getting the 240sx tuned with a supra swap...Larry get me in before June 1st
imapimp is offline   Reply With Quote
Old 05-15-2013, 08:59 AM   #790
Cipri
My Ride: E46 M3 2002
New SP Project
Will you drive the car before Christmas?
Just joking, currently I'm in the same situation like you with my tuner, he works on 20 cars and doesn't finish any of them on time...
Cipri is offline   Reply With Quote
Old 05-15-2013, 02:11 PM   #791
Twin_Turbo_S54
My Ride: M3
Cipri,
thats what made me tune my own M3s
To give you an idea, install Team Viewer and I can log online and map your M3.
Which stand alone do you have?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 05-15-2013, 02:46 PM   #792
Cipri
New SP Project
It's not only ECU tune, he needs to do also a lot of mechanical work.
Thanks for the offer, I have sent you a pm.
Old 05-17-2013, 01:49 AM   #793
Reid@SP
Regional Sponsor
Reid@SP's Avatar
My Ride: Toyota Supra
Send a message via AIM to Reid@SP Send a message via Yahoo to Reid@SP
Just got home. I'll let Nikolai post the details but we still seem to have a mechanical issue on the exhaust side. More to come tomorrow.
Sound Performance
Shop (630) 893-5002
Cell (847) 363-3139
reid@spracingonline.com
**PLEASE DO NOT PM ME!! Please email me for inquiries/communicaton**
Reid@SP is offline   Reply With Quote
Old 05-17-2013, 10:12 AM   #794
MisterM
My Ride: 03 M3
Oh no. Good luck and hope for a speedy recovery.
Old 05-17-2013, 01:03 PM   #795
NikolaiD
My Ride: 2002 M3C
Send a message via AIM to NikolaiD Send a message via MSN to NikolaiD Send a message via Yahoo to NikolaiD
So, here is the status report.
First, the progress.
We did all new seals and new bolts on the sprockets, hubs, vanos pistons, new pressure valve filter, and even replaced a "damaged" electrical connector for the solenoid coil pack.
The VANOS codes are gone (at least for now, the car wasn't driven, but the code used to pop right back up before), the only error code shown now is for the DME cooling fan and it's because it's not connected.
The vanos shows "adapted", the intake cam works 100% perfect, but the exhaust is not going to it's target.
When the car idles and target is 0, the cam shows 0-2, which is okay, but when we blip the throttle and target angle goes to 13-14, actual value doesn't follow it. Most of the time it only goes up to 3-4 degrees.
We'll try swapping cam sensors and even the whole vanos unit to isolate the problem, but it's time consuming.
If anybody has ideas, please share.
ID:	506046   Click image for larger version
ID:	506047   Click image for larger version
ID:	506048   Click image for larger version
_______________________________________
My Ride: 2002 M3C
NikolaiD is offline   Reply With Quote
Old 05-17-2013, 03:35 PM   #796
being3
Modded ///Member
being3's Avatar
New SP Project
Just an idea : from my understanding the car lifted the head. It was repaired and now cams r not working. Have u checked to see if the cam is binding because the head could be slightly warped? It should move freely with Vanos partially removed... Ie when the setting timing...
Just re read this and u said car was running so cams must be freely moving. My bad
Old 05-17-2013, 03:47 PM   #797
being3
Modded ///Member
being3's Avatar
New SP Project
I put my valve body in an ultrasonic cleaner u might have a clogged oil gallery. Have u replaced the selinoid ( black plastic) they r prone to fail.
Old 05-17-2013, 09:08 PM   #798
E85head
My Ride: E46 M3
Tom. What do you think about the ProEFI, and the driveability of your car?
E85head is offline   Reply With Quote
Old 05-24-2013, 05:29 PM   #799
Sound Performance
Past Site Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
Just made 1050 on boost alone!!
Sound Performance is offline   Reply With Quote
Old 05-24-2013, 05:31 PM   #800
Commanderwiggin
Nice! Lets get some vids!
