Old 12-15-2011, 10:00 AM   #1
DroppedE46
My Ride: e4sexxx
What is this noise?
I'm getting a noise in my passenger side rear.. Clicking noise, kind of sounds like an axel... It's louder in 1st and 2nd gear.. Doesn't happen when car is in neutral. Anyone know what this could be?
DroppedE46 is offline   Reply With Quote
Old 12-15-2011, 05:42 PM   #2
DroppedE46
My Ride: e4sexxx
Anyone?
Old 12-15-2011, 09:26 PM   #3
g1jigga23
My Ride: 2001 bmw e46
Check for a spring type clamp on the rear brake pad that holds it tight I accidentally left mine off and it did that noise and drove me crazy
g1jigga23 is offline   Reply With Quote
Old 12-16-2011, 08:11 AM   #4
DroppedE46
My Ride: e4sexxx
Did it sound like an axel? My mechanic went through the whole car and said everything was good but I need to get rid of this noise
Old 12-16-2011, 08:22 AM   #5
g1jigga23
Yes it did I ended up replacing my axle and wheel bearing for nothing. U can tell by applying the brakes as it makes the noise. If its that it should stop cause it squeezes the pads
Old 12-16-2011, 02:18 PM   #6
g1jigga23
Did you try it
