E46 Xi Forum
Old 12-07-2011, 05:14 PM   #1
R3C0NF1GUR3D_GRIM
My Ride: 330xi
Exclamation looking for some help
I have a 04 330xi and i just put on a set of gt7 rims on my car and after i drove about a mile my dsc and abs lights both came on. I have been told that i need to go to a dealership to get is fixed but i really don't want to do that bc of the insane cost of the dealer. If anyone even remotely knows what this is any help would be greatly appreciated.
R3C0NF1GUR3D_GRIM is offline   Reply With Quote
Old 12-07-2011, 05:21 PM   #2
SamDoe1
My Ride: 4cyl of fury
Check the wheel speed sensor on all of the wheels. What size rims and tires did you put on?
Old 12-08-2011, 12:34 PM   #3
R3C0NF1GUR3D_GRIM
My Ride: 330xi
i went to 18''-8''.5 front and 18''-9''.5 rear do you know how much wheel sensors cost?
Old 12-08-2011, 02:28 PM   #4
Kubica
My Ride: 2003 325xi
^what size tires are on the front/back?
Staggered setup on xi makes handling worse btw.
Old 12-08-2011, 02:46 PM   #5
SamDoe1
They are listed at $137.58 each and are part number 34526756382. You should be able to get it for cheaper than this if you go to one of the vendors on here. Mike at TheBMWPartsstore is very highly recommended. Sometimes just cleaning them up will help, sometimes it won't.
It's number 10 in this diagram:
http://www.realoem.com/bmw/showparts...64&hg=31&fg=10
Old 12-08-2011, 03:05 PM   #6
jasonbimmer
My Ride: 2001 BMW 330xi
do front and back tires have same size?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-08-2011, 03:06 PM   #7
CSL323
My Ride: 330Ci
Hmm. Could be unbalanced?
CSL323 is offline   Reply With Quote
Old 12-09-2011, 10:48 PM   #8
R3C0NF1GUR3D_GRIM
My Ride: 330xi
I am getting them all rebalanced. I have noticed the difference in handling but it is not that much different from stock. I also don't race with it any more so i don't really care. The and random people telling me that I have a bad ass car makes up for it... kinda. I am going to have to look in to the new sensors years of living at the beach have caused rust to set in to several spots. wheels all around are the same diameter 18'' but the back ones are a slightly wider so they require a thicker tier but not by much. SamDoe1 thanks the diagram was a big help.
Old 12-10-2011, 08:59 AM   #9
Kubica
My Ride: 2003 325xi
^ Just tell us what size tires you bought.
Old 12-11-2011, 06:41 AM   #10
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Easiest thing and quickest thing to check is to make sure that the wheel sensor wires are all in place and have not been cut by accident when installing the new wheels and tires. The wheels and tires (as long as the fitment is correct) would have no bearing on the dsc and abs system (unless the rear overall diameter is different than the front, then the 4 wheels and tires are not traveling at the same speed and this can cause an error to the dsc and abs).
I know others have done it, but on an all wheel drive, much better to have a square wheel/tire set than a staggered set, just from the stand point of handling and being able to rotate the tires for longer tread life.
tomoyer is offline   Reply With Quote
Old 12-11-2011, 10:34 AM   #11
Gus330vrum
My Ride: 330ci
Truee! My setup is staggered.. The back tires are little bigger in diameter .. Which I have realized is causing bad handling on highway.. I'm just waiting to use the tire more.. And I'm buy new set of all same size ..
Gus330vrum is offline   Reply With Quote
Old 12-11-2011, 10:52 AM   #12
tomoyer
Also with a staggered set-up (when rears are slightly larger in diameter than the fronts), is also hard on the all wheel drive system because both the front and rear end should be turning at same speed and travel same distance per rotation (often to hard to perfectly match overall diameter between fronts and rears in staggered set-up, where as on a rear wheel drive, the staggered set-up doesn't come into play too much, and yes, the wider tires on the rear than the front does look good, just not good for all-wheel drive.
Old 12-11-2011, 02:47 PM   #13
R3C0NF1GUR3D_GRIM
My Ride: 330xi
Thanks tomoyer found a sensor wire that had been ripped out on the front right side and i am going to get it fixed soon, hopefully all the lights go out. I am going to replace the rear tiers soon too.
help found thanks
Old 12-11-2011, 06:01 PM   #14
tomoyer
In the future, if you do some work such as what you did and almost immediately have a warning light, go right in there and check for unplugged or damaged wiring for that system, nine times out of ten that's what happened and is an easy fix.
If the wire(s) are torn that you have some on either end, as a temporary fix you can splice them together while awaiting the new wire(s) to replace (though you can not do this if the wires have been pulled from the senor and there's nothing left to splice to.
Glad to be of help.
