Diagnose: Engine Click - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-07-2011, 06:26 PM   #1
kylekylekyle
My Ride: 2001 Black 330CI
So yesterday I noticed this clicking noise when the engine is running...
Video...
A few weeks ago I had screeching but I fixed that by replacing...
Both Tensioners
Both Pulleys
Water Pump (Pulley Only w/ Aluminum)
Both Belts
... then everything was quiet and smooth.
A week ago my battery went dead at work (wouldn't go beyond click noise) so I got jump started by a VW then drove home. I bought a new battery and swapped it out. Car started right up fine all week and still starts fine.
What could be clicking?
Can the alternator wheel/pulley be clicking?
I had plans to replace the water pump first.
Could the Water Pump be clicking?
kylekylekyle is offline   Reply With Quote
Old 12-07-2011, 06:27 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
Disa
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-07-2011, 06:31 PM   #3
Fuzzzy
My Ride: 2002 330i
Originally Posted by jasonbimmer View Post
Disa
+1
Get that sh!t checked.
Fuzzzy is offline   Reply With Quote
Old 12-07-2011, 06:44 PM   #4
Hellvis
My Ride: 05 325xi
disa
+2
Hellvis is offline   Reply With Quote
Old 12-07-2011, 06:44 PM   #5
kylekylekyle
seems pretty easy to replace... anyone have part # off hand?
FOUND IT: Adjuster unit #11617544805 about $200
I'm gonna test it by unplugging the sensor when i get home but I did find the part.
Old 12-07-2011, 09:22 PM   #6
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
disa valve is above your throttle body. it is located in the center of your intake manifold (on the side)
Old 12-07-2011, 09:49 PM   #7
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
+3
BMWCaptain is offline   Reply With Quote
Old 12-08-2011, 03:41 AM   #8
kylekylekyle
i saw some youtuber videos on it. Seems simple enough and I looked closer when I got home. It definitely sounds like its right up in that area. Its hard to tell because its up in the air intake area so it kind of reverberates. But it seems likes it is the Disa plus from other posts it seems replacing the Disa would be a great idea for improving worn performance anyways. I'm going to most likley order the part tomorrow and swap the sucker out.
Old 12-08-2011, 04:06 AM   #9
Danoff
My Ride: '04 330i ZSP
Search for DISA on youtube, you should find a video where a guy shows you how to unplug it. You can do this while the car is idling to prove that it is what's clicking. Happened to me, I unplugged it, clicking stopped, plugged it back in, ordered a new DISA, swapped it out. Job jobbed. (Clean the MAF while you're in there)
There is also a DIY on this forum about how to repair the device yourself using some epoxy (no new DISA required), but it's dangerous because it requires loosening a pin that you then really really need to get secured back in place. If that pin ever comes loose it goes into the engine.
Danoff is offline   Reply With Quote
Old 12-08-2011, 04:40 AM   #10
Pedi
My Ride: 330ci
doesn't sound like when my DISA went bad. DISA is plastic but in your video it sounds like metal. Have you done your vanos yet?
Pedi is offline   Reply With Quote
Old 12-08-2011, 12:06 PM   #11
kylekylekyle
Have I replaced DISA? no
Have I replaced VANOS? no
I unplugged the sensor to the DISA and the click remained. Here is another video with better sound.
Old 12-31-2011, 03:13 AM   #12
kylekylekyle
SOLUTION: It was not the DISA... it was the Power steering pump. Replaced. Sound is now gone.
330ci, bmw, click, clicking, engine clicking
