Old 12-08-2011, 05:41 AM   #1
zooyorkE46
My Ride: E46 325ci
325CI overheating please help
Workin on a E46 325Ci thats been overheating i replaced the thermostat replaced the water pump checked the heater core valve i guess you kno the valve tht gives u warm air for your heater but anyway it functioned jus fine and when i fill the tank up with water it gets full but the water dont seem to go any where unless i take the bleed screw out all the way ive tried bleeding the system multiple times. Can anyone give me any suggestions?
zooyorkE46 is offline   Reply With Quote
Old 12-08-2011, 07:34 AM   #2
Sansho
My Ride: 2001 325i
Describe the steps you take to bleed the system ....
Sansho is offline   Reply With Quote
Old 12-08-2011, 08:07 AM   #3
EDawg
My Ride: :/
1. put key in ignition and turn to position II.
2. set fan to lowest speed, and set temp to max (91 degrees).
3. remove bleeder screw. also remove reservoir tank cap.
4. with ignition still in position II, pour coolant/water through reservoir tank until coolant/water spills out of bleeder hole without any bubbles.
5. reinstall bleeder screw and reservoir tank cap.
6. start engine and drive car around till engine reaches operating temp.
7. let engine cool and check coolant level. top off coolant to proper level if necessary.
EDawg is offline   Reply With Quote
Old 12-08-2011, 08:20 AM   #4
jasonbimmer
My Ride: 2001 BMW 330xi
when your engine over heats, does the radiator appear warm?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 12-08-2011, 08:26 AM   #5
lsteg
My Ride: 2001 330ci
if your steps don't match this exactly then you're doing something wrong.
lsteg is offline   Reply With Quote
Old 12-08-2011, 08:59 AM   #6
zooyorkE46
My Ride: E46 325ci
I have my thermostat rigged to b open constantly also
Old 12-08-2011, 09:02 AM   #7
zooyorkE46
My Ride: E46 325ci
What do i do after those steps? and if my radiator dont warm up does that mean its blocked up?
Old 12-08-2011, 09:09 AM   #8
zooyorkE46
My Ride: E46 325ci
It seems to take a minute to start heating up it takes like 10-20 mins to get completely hot depending on how the weather is outside
Old 12-08-2011, 09:25 AM   #9
jasonbimmer
I am thinking your thermostat is still stuck shut if the radiator is not getting warm.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 12-08-2011, 09:27 AM   #10
EDawg
My Ride: :/
Originally Posted by BMW-North View Post
Why do you need to drive the car "around"?
I've successfully bled 50+ times and never moved the car from the garage?
Raising the front end and revving the engine has sufficed?
I think most of the probs I read about on here with bleeding coolant is due to folk not waiting till the thermostat is open to ensure the circulation is occuring and then topping off.
driving the car "around" just facilitates the warming up process to get the thermostat to open up. if you want to rev the engine up in your garage/driveway, then by all means, go for it. i just don't like to subject my neighbors to excessive noise, nor do i want to subject the people around me, including myself, to breathing in excessive exhaust fumes.
Old 12-08-2011, 09:32 AM   #11
lsteg
My Ride: 2001 330ci
rev the car - drive the car around
6 of one, half dozen of the other
...the bottom line is to get the thermostat open.
Old 12-08-2011, 09:42 AM   #12
lsteg
My Ride: 2001 330ci
I hear you and I understand why you are driving the car around - but if you're working on a coolant system - say a component replacement or a flush - you've removed the belly pan to drain the block, possibly removed belts and replaced, disconnected and re-attached the fragile paper clip BMW hose connectors -if anything went wrong - i wouldn't want to be far from where I could easily fix it. Plus I put the belly pan back on last thing before lowering car.
Driving the car around is unnecessary to open the thermostat - just didn't want newbies thinking that the motion of the vehicle contributed anything.
I agree. much easier and safer to stay in the driveway. no reason to complicate the situation.
coolant, overheating, trouble
