///M3 Forum
Old 12-03-2011, 11:29 PM   #1
new//M3fan
My Ride: 77' 924 87' E30
new//m3fan's dyno runs
1st run - 3rd gear
2nd run - 4th gear
HP/RPM both runs
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 12-03-2011, 11:33 PM   #2
Gheybe
Gheybe's Avatar
My Ride: F80 M3
mods?
Gheybe is offline   Reply With Quote
Old 12-03-2011, 11:45 PM   #3
new//M3fan
Originally Posted by Gheybe View Post
mods?
None.
But what I have done is the following.
Cleaned MAF, This procceedure on about 15 or so connectors. ( have yet to do the Intake cam sensor) http://forum.e46fanatics.com/showthr...781&highlight=, latest ECU update, cam bolt swap (might have properly re-set VANOS timing? I used the BMW timing tool), RL trans fluid, new fuel filter, and a 5:1 ratio of 2 cycle marine TC-W3 oil in the gas tank.
That's it. I should ad that the car was put in dyno mode. Allowing a 8k redline. Otherwise it would have stopped at 6300rpm and gave a readout of about 270~hp.
Old 12-04-2011, 05:56 PM   #4
M3simy
My Ride: Bmw e46 m3
Originally Posted by new//M3fan View Post
None.
Is that whp?
M3simy is offline   Reply With Quote
Old 12-04-2011, 09:34 PM   #5
new//M3fan
Originally Posted by M3simy View Post
Is that whp?
yes
Old 12-04-2011, 10:56 PM   #6
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
Thats uncorrected.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 12-04-2011, 11:01 PM   #7
$ilent ///M
My Ride: 03.5 M3 smg lsb
Thats a good run i got almost 270hp and 236tq with mine but that was at 6300rpm. I didn't know how to disable the dsc at the time. Kind of wondering what i wouldve made. only mods are k&n drop in filter with elbow and titanium exhaust also have high mileage well over 130,000 miles. We calculated 280hp using a formula in class, so it did come close to it, if it had went to 8k rpm. Congrats on the dyno run.
$ilent ///M is offline   Reply With Quote
Old 12-05-2011, 10:39 AM   #8
new//M3fan
Thanks!
Another M3 was there and on his first run it only went up to 6300rpm and he made 272hp, then I put the DME into Dyno mode for him allowing him to hit 8k..
Old 12-05-2011, 10:40 AM   #9
new//M3fan
Originally Posted by grkm3 View Post
Thats uncorrected.
Yes, Hopefully I'll get the .DRF file today to correct the graph.
Old 12-05-2011, 10:52 AM   #10
new//M3fan
The car was dyno'd at http://www.inlinepro.com/s1/s-2-tuning-services.aspx
Old 12-05-2011, 02:02 PM   #11
$ilent ///M
Thanks!
Do you remember what he hit at 8k
Old 12-06-2011, 10:25 AM   #12
new//M3fan
Old 12-06-2011, 11:04 AM   #13
J.J4ck0wsk1
My Ride: 04 IR M3 Coupe M/T
^ I don't think that's readable lol.
04 Imola Red E46 ///M3 Coupe M/T
J.J4ck0wsk1 is offline   Reply With Quote
Old 12-06-2011, 12:53 PM   #14
M3simy
My Ride: Bmw e46 m3
yes
Thats a very good power figure for a stock m3. Just goes to show how maintaing your car keeps it healthy. Congrats on the dyno.
Old 12-06-2011, 01:41 PM   #15
NorthJersey 3er
NorthJersey 3er's Avatar
My Ride: '03 M3 / '72 2002tii
Whats the point of going into dyno mode?
Matt
co-founder of
euro techniks
NorthJersey 3er is offline   Reply With Quote
Old 12-06-2011, 03:42 PM   #16
new//M3fan
Thanks!
Old 12-06-2011, 03:43 PM   #17
new//M3fan
look again.
I just noticed I was sent .jpg's (In hp/mph instead of hp/rpm) and also instead of the .drf files; I had asked. I've had a bit of trouble getting what I'm asking for from them.
My friends M3 also had a K&N intake system. but no other maintenance done to the engine besides fresh oil.
Old 12-07-2011, 02:47 PM   #18
theinfamousdrew
My Ride: 911 Turbo / E70
how did you put it in dyno mode?
theinfamousdrew is offline   Reply With Quote
Old 12-07-2011, 03:06 PM   #19
bimmerfan08
My Ride: F
Max hp is higher than 6300 rpms
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 12-07-2011, 09:23 PM   #20
SexiPYm3
My Ride: 03 M3
Those are good numbers. Very similar to mine. I did 297whp and 249tq earlier this year. I will try to locate my graph to post.
SexiPYm3 is offline   Reply With Quote
