Old 12-08-2011, 04:45 PM   #1
cyberlando
My Ride: 2002 M3
Suspensions for K&W
does anyone out there know where to use the key for my KW suspensions to soften up it ride.
there is something in the whole where my strut bar goes that goes to the shocks its a little twisting knob.......
all i wanna do is just soften the ride up a little i understand its a sport suspension which is suppose to ride hard but it must be able to be softened up a little
the car is lowered the front tires are 235 35 19
and the backs are 265 30 19
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 12-08-2011, 05:20 PM   #2
lcoleman
My Ride: '79 Massey Ferguson
You can change the damping, but it's not really going to improve the ride because the spring rates are fixed. If anything, I'd probably turn the damping up--it might actually help. Nothing worse than a damper that's too soft for the spring.
Old 12-08-2011, 05:27 PM   #3
trippmann
My Ride: E30
Send a message via AIM to trippmann
kw v1, v2, or v3?
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 12-08-2011, 05:48 PM   #4
ModBargains III
ModBargains III's Avatar
My Ride: E46
Not necessarily true... You will notice a slightly less stiff ride if you turn it down even if you just have V2's and you can only adjust rebound which still makes it a bit more comfortable. I've done so on my V2's and I notice a huge difference in ride comfort when turned down.
Originally Posted by trippmann View Post
kw v1, v2, or v3?
Good point... V1's don't have any adjustments, only V2's and V3's.
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 12-08-2011, 05:49 PM   #5
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
front - top of the shock
rear- requires to take the shock off to adjust the damper
Devious1 is offline   Reply With Quote
Old 12-08-2011, 08:27 PM   #6
cyberlando
My Ride: 2002 M3
It says 1001 on there so its the v1 I think not sure.
how do I adjust the dampening where does the key fit......and can you guys tell me wat im looking for and wat direction as far as to soften and stiffen it should I turn
Engine:
Interior:
coilover, shocks, sport springs, suspension, tires
