Old 12-11-2011, 08:45 AM   #1
jordangreen21
My Ride: e46 m3
O2 sensor problem
So I had catless headers and everything was fine but I am about to sell my car so I put the stock headers back on. After installing them and putting all the o2 sensor back in the car is running like ****. I've heard having the sensors in wrong can cause this to happen. Any help would be appreciated. Thank you
D2 Racing Sport Suspension ~ aFe CAI ~ AA Tune ~ Orion AEs ~ Topspeed Exhaust ~ Euro Headers ~ UUC SSK Evo 3 and DSSR ~ 15% Tint Windows and 50% Windshield
jordangreen21 is offline   Reply With Quote
Old 12-11-2011, 11:47 AM   #2
trippmann
My Ride: E30
Send a message via AIM to trippmann
yeah you probably have the sensors in the wrong bungs. swap your precat connectors and see if it helps. the postcats usually dont have much to with performance its more about emissions.
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 12-13-2011, 05:19 PM   #3
jordangreen21
My Ride: e46 m3
switched em around and it worked but for some reason I am getting a slightly rough idle.
Old 12-13-2011, 10:20 PM   #4
darksideracer69
My Ride: 01 325ci
weird
IMAG02051
Old 12-15-2011, 08:05 AM   #5
trippmann
My Ride: E30
Check for exhaust leaks and vacuum leaks. Good luck
Sent from my DROIDX using Bimmer
Old 12-23-2011, 03:19 AM   #6
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
yeah the idle problem is probably from exhaust leaks at the oem manifolds not being bolted up all the way tight or maybe a bad gasket. could be header to exhaust flange too
drumbum624 is offline   Reply With Quote
