E46 Xi Forum
Old 12-10-2011, 07:54 PM   #1
davesalkin
My Ride: 04 330 XI
Outside chrome molding
Hi Group:
On my 04 330XI the chrome molding that surrounds the windows is very oxidized. Especially around the rear windows. I have tried different types of cleaners and polish. The same results it doesn't look good. Anybody have any luck with a product. I am told this is common with these cars.
Dave
davesalkin is offline   Reply With Quote
Old 12-10-2011, 08:13 PM   #2
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
You can try Eagle One's Never-Dull wadding polish. Will work, but be careful not to get the cleaner/polish on any black or painted surfaces. Most auto parts stores carry it as well as WalMart.
tomoyer is offline   Reply With Quote
Old 12-10-2011, 08:27 PM   #3
fastjasonbmw
My Ride: 330Xi
There's a bulletin that lists a product to help this situation. No time to look it up right now. I'll look up the bulletin tomorrow and report back.
fastjasonbmw is offline   Reply With Quote
Old 12-10-2011, 08:47 PM   #4
GMrc51
My Ride: 2001 325 coupe topaz
PlastiDip .....or wrap....tried all the stuff they selll...no bueno...doesnt last....plastidip time consuming but it does the job....also better to apply when 70 degrees or higher...smooth finish....
Sent from my PC36100
GMrc51 is offline   Reply With Quote
Old 12-10-2011, 09:15 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I got some product that really didn't work, but the initial phase of the prep work was sanding with fine grit sandpaper...like 1500/2000. I just polished mine like the metal it is. I followed with flitz (filtz? Some metal polish) and now, just maintain it periodically with magic eraser.
Get the finest sandpapers you can get...and mask adjacent areas...not good on paint! Take your time, use long straight strokes. Work fine on grit as needed.
HTH
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 12-10-2011, 10:25 PM   #6
tomoyer
You can also pick up a fine grit Scotch Brite Pad to clean the moulding followed with the Never-Dull. You will have to use the Never-Dull once a month or so to keep them looking good. You will definitely want to mask off the painted areas around the moulding (make the tape several layers thick). Scotch Brite Pads can be picked up at auto body supply places and a Grainger (we used them to polish tool steel, they are available in pads and "wheels" for die grinders, I recommend the pads for what you are doing. There are several "grits", you want the finest).
Old 12-11-2011, 02:31 PM   #7
fastjasonbmw
My Ride: 330Xi
The bulletin (SIB 51 53 02) specifically describes discoloration of the glossy black shadowline trim. But I have used the same product on the chome trim.
The bulletin states that deposits that cause the discoloration can be easily removed by polishing with a quality swirl removing polish, such as Meguiars #9.
http://www.autogeek.net/meg9swirrem.html
