Old 12-11-2011, 01:24 PM   #1
cyberlando
My Ride: 2002 M3
Lightbulb M54 330ci
my engine has about 159k on it just curious how long have you heard these engines lasting?
200?
of course with proper maintenance!
starting to get a little nervous the higher the number climbs...lol
starting to think about buying an engine to replace it......
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 12-11-2011, 01:40 PM   #2
InTheBeams
My Ride: 02 330i Sport Pkg.
I dont know about the 330i exactly but I've seen plenty and heard of plenty E46's running great over 200+ with proper maintenance. Is your engine acting weird at all currently? If its running fine right now and your just afraid of the number 159k then I wouldn't worry until something doesn't feel right with your car. Maintenance, maintenance, MAINTENANCE!
InTheBeams is offline   Reply With Quote
Old 12-11-2011, 01:44 PM   #3
Stinger9
My Ride: '04 330Ci
So, let's get this straight?
You're jumping the gun on replacing a perfectly good engine that's working well with a used engine?
Some on this board report cars in the 250K miles range.
What are you expecting to be the specific area or part that will wear out to doom your engine?
Bottom line is that you should take care of this engine until the engine lets you know that it will work no more. At that time the message will be clear.
Old 12-11-2011, 01:57 PM   #4
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
^This... just keep up with the maintenance
Drew@Swift Motorworks is offline   Reply With Quote
Old 12-11-2011, 02:07 PM   #5
Andy2108
My Ride: SpecE46 & E46 M3
The odometer stops working at about 450,000 km or miles, so noone really knows.
Old 12-11-2011, 02:17 PM   #6
SweTurbo
Big Pimpin'
My Ride: 323i -98
No but really the only thing that wears out on M54's are the piston rings and oilpump nut.
Do a leakdown test to see how well your rings work and just be happy with it
330ci, engine, maintenance
