Thread Tools Search this Thread Rating: Thread Rating: 95 votes, 5.00 average. Display Modes
Old 11-24-2012, 10:01 PM   #21
Kititolay
My Ride: E46 328i
Thanks for the post
Kititolay is offline   Reply With Quote
Old 12-30-2012, 05:38 PM   #22
username11
My Ride: 13 E92 M3, 11 E92 M3
Thanks for this DIY. I am following it in approximation for an M3.
Just wanted to share my experience with trying to take the pump apart. I tried the pry method with a thin screwdriver, no luck. After about an hour of trying I smashed the **** out of it with a hammer. My logic being if I couldn't get it open to repair it I might as well see what it looked like inside.
The motor turned out to be completely rusted out and bound up; but after a bit of jimmying I got the armature free. So I could have fixed it.
You will need to vice clamps that you can twist separately with a lot of forced to properly get this thing apart if it is seized. Prying will probably not work like it did for the OP.
username11 is offline   Reply With Quote
Old 01-01-2013, 01:44 PM   #23
adrianpl
My Ride: 01 330ci
You can buy one for $8 bucks. But if you like a challenge go for it. Great DIY
adrianpl is offline   Reply With Quote
Old 01-02-2013, 08:25 AM   #24
G3n15z
My Ride: '00 BMW 318i
Send a message via MSN to G3n15z
Great DIY
G3n15z is offline   Reply With Quote
Old 01-25-2013, 10:38 AM   #25
Chris3Duke
My washers aren't working. Any chance the lines could be frozen if the tank isn't? It's been in the teens for a week here.
I guess the next step is to test the voltage with a multimeter, then go from there.
Chris3Duke is offline   Reply With Quote
Old 02-24-2013, 12:33 AM   #26
mikeypx82
My Ride: 2005 BMW 330i
Windshield washers not working
Originally Posted by scsnospam View Post
My washers stopped spraying suddenly. I first got a warning about low washer fluid level, went out and bought some fluid and poured in about 0.5 gallon. Tried to spray after a couple of days, nothing. Not even relays clicking, or motor trying to turn.
If I check the voltage on the cable connector with a very good multimeter, it reads 9.6V even when the car is off, no key in ignition. On turning on, and clicking the wheel wand for spray, no change in voltage, still about 9.6V.
I read somewhere that the wiper relay could be bad in the E-box.
1. Does the wiper relay also control spray motor?
2. Can i test the relay before purchasing replacement? Can i swap in another relay from the e-box?
3. If I have to replace the pump, will any aftermarket pump be ok?
thanks.
Did you ever figure out what the problem was? I'm having the same issue.
I recently bought a 2005 330i. Mine came with headlight washers and they ARE working but the windshield washers are NOT working. I checked to voltage on the windshield washer connection and it reads 9.3V even when the car is off and the key is out of the ignition. The headlight washers read 0V when the car is off and the key is out of the ignition.
I checked the fuses, they are all fine.
mikeypx82 is offline   Reply With Quote
Old 03-20-2013, 06:45 PM   #27
pop12pop
My Ride: 03 325
Guys,if you pull out the motor you'll see there is a little rubber washer between the motor spindle and the bottom of the plastic container.I put some bath tub silicone on the washer and put the motor back in now the little square weep hole is not leaking anymore.
pop12pop is offline   Reply With Quote
Old 05-16-2013, 09:22 PM   #28
Skunk0001
My Ride: E46
+1 on the "Great Post". Fixed my washers in 10 mins.
Skunk0001 is offline   Reply With Quote
Old 06-26-2013, 01:19 PM   #29
mybmwisallst0ck
My Ride: BMW '02-330Ci, '99M3
Glad I checked here.
Mine stopped working a few months ago, hope this can fix it.
EDIT: Used the T taps, I assumed the red wire was the hot wire and connected that to the BROWN wire on the BMW. I also assumed that the Non-red wire (Yellow) was ground and black on the bmw was ground.
Tapped it in, connected it and nothing.... come back hour later and try it again and it started sputtering out. Got a needle to clean up the spray and it works!
$18 for pump and fluid. THANKS!
removed old sig
mybmwisallst0ck is offline   Reply With Quote
Old 10-19-2013, 06:16 AM   #30
lwr
My Ride: BMW E46
Thanks for the tutorial, it's great. I'm a 28 y girl, and I needed to change the washer fluid pump. My uncle didn't wanted to help me, so I just tried for myself and managed.
I feel great and thanks a lot again!
lwr is offline   Reply With Quote
Old 10-19-2013, 09:40 AM   #31
Sansho
My Ride: 2001 325i
Congratulations! It's a good feeling when you can fix something yourself, and it works!
Sansho is offline   Reply With Quote
Old 01-26-2014, 07:19 AM   #32
Anderspr0
My Ride: E46 320ia
Lol, just bought a new. Costed less than 5 bucks at ebay. Last for a while
E46 320i, 19", Xenon, LED fogs, shadowline, tinted turns, foglights and headlight, tinted windows, M3 bumper, CF interiortrim, CF emblems ++
Anderspr0 is offline   Reply With Quote
Old 01-26-2014, 11:16 AM   #33
gselsidi
My Ride: 2005 325i M56
Yea for $8 bucks this isn't worth the time, but if you want to tinker around with something it's great. What happened to mine, my pump didnt fail but that stupid hose became loose for some reason and would keep sliding off the pump, some duct tape solved the problem lol.
gselsidi is offline   Reply With Quote
Old 01-27-2014, 10:03 AM   #34
BillB
My Ride: e46
Awesome DIY write up. Although mine was so bad that the body of the motor was rusted and falling apart. I ordered a new pump off of EBay for 6.00.
BillB is offline   Reply With Quote
Old 09-20-2014, 09:46 PM   #35
RDR
My Ride: 325Ci
Leaky washer resouvoir
Great explanation of the puimp. Can you tell me what I should expect when I pull the unit out? It is leaking where the pump fits the tank. Is there some seal there?
RDR is offline   Reply With Quote
Old 03-31-2015, 03:06 PM   #36
jmonica
My Ride: 2006 GMC Envoy
Let me say THANK YOU very much. I noticed a few people commented that it made more sense to just replace the motor rather than repair it. I don't drive a BMW, I've never owned a BMW (though I'd like to), but your article saved me a nice chunk of change. A google search brings up article after article with titles such as "How to repair your windshield washer pump", but not one of them explained how to repair anything. They all illustrate how to replace a pump. It's rare to find someone who actually does repairs on vehicles any more instead of just parting out the problem. Granted sometimes its not worth it to repair some things and it does make more sense to replace a broken part, but in this case, the washer pump motor for my headlights is over $65 new and that's for an aftermarket one. Pumps for the front and rear windows are cheap at $15 each so I did replace those when they failed but I can't see spending $65 if I can take the old one apart and fix it. And well now thanks to you, that's exactly what I am going to [attempt] to do. I can't wait to get in there and see what the problem is. I just wasn't sure how to get the case open without worrying about cracking it. but I'm sure it comes apart the same or similar to the one that you took apart. Your post was awesome in terms of the pictures and the annotations. Not too wordy but yet it didn't leave out anything essential. It was perfect as were the photos that you posted. You should do this for a living! Anyway, Thank You again for taking the time to help others. And even though I don't yet drive a Bimmer, You certainly helped inspire me to try to fix mine and potentially save some cash. Best of luck in the future and Thank You again mate!
jmonica is offline   Reply With Quote
Old 03-31-2015, 03:13 PM   #37
jmonica
Wow what an amazing idea. You are a genius. You bought a new one? Why didn't anyone else think of that great idea? Umm You missed the point of this post. This is for people who actually want to fix their car, not just keep buying parts until they solve the problem. That's the difference between you and the gentleman that posted this great DIY. What did your smart ass post add to this discussion? Do you think you outsmarted everyone by purchasing a new pump? WOW, what a brainiac. You are amazing. I'll bet nobody else ever thought of buying a new pump on eBay. You've got a true gift my man. You are going places in this world!
Old 04-22-2015, 06:03 AM   #38
k9fxr
My Ride: 325ci vert 2006
This article doesnt address the disconnect for the headlamp washer pump. Mine looks like it has a hose that is clamped and a factory install zip tie leaving the pump. I was thinking this should be a quick disconnect, will that be more obvious when I pull the tank up (waiting for the washer pump to arrive before pulling it apart)?
k9fxr is offline   Reply With Quote
Old 06-12-2015, 09:58 AM   #39
syana
My Ride: car
Thank you very wonderful thread Nickvjr.
syana is offline   Reply With Quote
Old 06-12-2015, 10:00 AM   #40
syana
My Ride: car
repair, replacement, windshield washer pump, windshield washer tank
