E46 Convertible
Old 12-12-2011, 03:18 PM   #1
2001bmw330cic
My Ride: 325cic
Need help. seat belt light blink
I just bought a 2004 BMW 325ci convertible with only 7,000 miles on it. The seat belt light blink on and off. If I put the key in the ignition and the seat belt light is sold, than it won't blink but it will blink after driving on and off. If it blink when I put in the key then it will blink on and off while I am driving also. Sometime it goes off for awhile while driving then goes on again blinking. Does anybody know what is wrong?
2001bmw330cic is offline   Reply With Quote
Old 12-12-2011, 03:23 PM   #2
kib
My Ride: bmw 04 e46 330 vert
some times the wires under the seat come loose have a look at the connections.
kib is offline   Reply With Quote
Old 12-12-2011, 03:57 PM   #3
2001bmw330cic
My Ride: 325cic
I check into that already. No lose connection.
Old 12-12-2011, 07:09 PM   #4
2001bmw330cic
My Ride: 325cic
Stop by auto to pull the code but no code show up.
Old 12-12-2011, 08:05 PM   #5
Irishdb
My Ride: ///M3
Anything heavy on the passenger seat?
2006///M3Vert/AO8/Nappa/SMG/19's/HK/NoYokes/MatteGills&Grills
Irishdb is offline   Reply With Quote
Old 12-12-2011, 08:31 PM   #6
2001bmw330cic
My Ride: 325cic
Try it with and without anybody on the passenger side. If I put the key in and turn it on and if the seat belt light is on solid than the light will turn off after in put on the seat belt. But the light will blink after driving. It will brink on for a while than off for awhile and on again. Sometime I can drive for half an hour than it will goes on again. Sometime it stay on blinking and doesn't goes off.
If I turn on the Ignition and it blink right away it will blink for awhile on and off.
Old 12-19-2011, 09:53 AM   #7
Rufffa
My Ride: 330cic
Got the same
I got the same problem.
I found the source of the problem- it`s a front seat switch.
It`s located under the driver`s and passenger`s seat.
It is resp. for lowering the headrest when You fold the seat.
Blinks when the sensor recognize the seat is fold down.
Rufffa is offline   Reply With Quote
Old 12-20-2011, 08:05 AM   #8
2001bmw330cic
My Ride: 325cic
Did you have to replaced the switch or just clean it?
Old 12-20-2011, 08:41 AM   #9
Rufffa
My Ride: 330cic
It`s O.K. if You just clean it with spray that removes oxidation from electrical contacts. But first You have to take out the whole seat to get to it.
Old 12-20-2011, 09:26 AM   #10
2001bmw330cic
My Ride: 325cic
Thanks, I'll try that over the holiday break.
Old 04-09-2013, 06:37 PM   #11
BeaMerWorld
My Ride: E46 M3 Cab
I am trying to do the same, is there a DIY or do you have photos when you did yours? I'm trying to figure out which one is the sensor that I need to clean.
BeaMerWorld is offline   Reply With Quote
Old 04-10-2013, 03:27 AM   #12
Rufffa
My Ride: 330cic
Hi.
Actually You don`t have to take out the seat. It is really an easy fix and will take You no more than half an hour.
Check out my video and photos here:
https://dl.dropbox.com/u/89258837/20120615021.mp4
https://dl.dropbox.com/u/89258837/20120615237.jpg
https://dl.dropbox.com/u/89258837/20120615238.jpg
Just make sure the metal spring is not broken, than clean it and ... that`s it . You don`t need to erase any errors in the ecu.
Have fun!
Old 04-10-2013, 10:12 AM   #13
jetad
My Ride: 2004 330cic
I had this same problem for months. Did several scans but no error code came up. One day I was vacuuming the car and decided to just wriggle and shake the wires under the drivers seat. This solved the problem. Might work for you too before you disconnect anything.
jetad is offline   Reply With Quote
Old 04-11-2013, 09:54 PM   #14
BeaMerWorld
My Ride: E46 M3 Cab
Rufffa check the video link, it's not working.
