Old 12-12-2011, 04:28 PM   #1
therealpbgamer
My Ride: 2002 330ci
Bad Vanos? Vanos leaking lots of oil. Need to replace seals, or entire unit?
So sometimes my car has a rough idle, and i figured i would have to clean my idle control valve, because my CCV stuff looks new, with no oil leaks. However, my yellow oil light came on the other night, so i added a little oil (not even a quart). The front part of the Vanos now is leaking oil over the waterpump, a radiator hose and serpentine belt. I figured i would have to replace the vanos piston seals, but a local mechanic told me it shouldn't be leakin on the front. I'm taking it in tomorrow for a free check. Ima DIYer, any thoughts or experience with this? Thanks!
therealpbgamer is offline   Reply With Quote
Old 12-13-2011, 11:04 AM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Is your Vanos oil line leaking? This leaks quite a bit.
BMWCaptain is offline   Reply With Quote
Old 01-27-2012, 02:20 AM   #3
co3deron
My Ride: E46 320I Touring
Changing the vanos seals is an easy DIY only it takes time to do it wright. If you do this wright you will have no leaks and you will notice a the better the perfomance of the engine. Look at www.beisansystems.com. Good luck.
co3deron is offline   Reply With Quote
