Old 12-13-2011, 03:23 PM   #1
chuckb210
My Ride: 2001 325Ci
cant depress clutch
I was driving normally on the highway when I couldn't depress the clutch anymore. Any ideas what would cause this.
chuckb210 is offline   Reply With Quote
Old 12-13-2011, 09:00 PM   #2
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Start with hydraulic - master / slave clutch cylinders, hoses. If not that - it becomes much more complicated and require transmission drop to figure out.
Nervous is offline   Reply With Quote
Old 12-13-2011, 09:04 PM   #3
chuckb210
My Ride: 2001 325Ci
Would this happen because the fluid is blocked or leaked out. The brake fluid container is full. Also is there anyway to test these items to see which one failed.
Old 12-13-2011, 10:30 PM   #4
Nervous
unbolt slave cylinder from transmission (from underneath of car) and ask a buddy to depress the clutch. Of the rod moves and no leaks - when hydraulic works.
Old 03-07-2012, 12:40 AM   #5
BMWUSMC3051
My Ride: 2000 BMW 323i
Check the lines for leaks then check the master slave clutch cylinder, for any obvious signs of leakage. Should be noticeable because the paint surrounding will be jacked, if it is leaking you can replace that. If not move to the slave clutch which should be closer to the tranny housing and do what was recommended in the previous post.
BMWUSMC3051 is offline   Reply With Quote
Old 03-07-2012, 09:52 AM   #6
chuckb210
My Ride: 2001 325Ci
We ended up taking it to Bavarian Auto Werke in Orland Park, IL. The guy is great. The clutch pad was shredded. He showed me the part. He rebuilt the clutch for under $700 (included parts). I thought it was a pretty good price and I would recommend him. A little bit of a drive. So, let me ask the pros.
Fair Price
Over Price
Great Price
I haven't had a problem since.
