Old 12-14-2011, 12:11 PM   #1
e.hilky
My Ride: 2004 330ci
M3 diff question
I have my 04 330ci and want a different diff in there. Is there any chance someone can chime in on if a m3 diff/lsd would fit in? Or is there something I'd have to do to make it work?
e.hilky is offline   Reply With Quote
Old 12-14-2011, 12:48 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
Popular question, seems to have been covered here 1000x before. The M3 diff isn't a direct drop in replacement for the non-M diff. For starters, it mounts differently. You can swap most of the M3 rear end over to make it work though. For more details, you'll need to search out the numerous prior discussions of this subject. Lots of good info to be found. In addition to the LSD, keep in mind the M3 diff has a 3.62 ratio compared to your stock 2.93 (assuming manual transmission) which is a little short for a 6500 rpm red line. Also keep in mind there are aftermarket LSD options which would allow for you to select the best ratio for your application.
Old 12-14-2011, 12:50 PM   #3
Gheybe
Gheybe's Avatar
My Ride: F80 M3
[QUOTE=TxZHP04;13891175]Popular question, seems to have been covered here 1000x before. The M3 diff isn't a direct drop in replacement for the non-M diff. For starters, it mounts differently. You can swap most of the M3 rear end over to make it work though. For more details, you'll need to search out the numerous prior discussions of this subject. Lots of good info to be found. In addition to the LSD, keep in mind the M3 diff has a 3.62 ratio compared to your stock 2.93 (assuming manual transmission) which is a little short for a 6500 rpm red line. Also keep in mind there are aftermarket LSD options which would allow for you to select the best ratio for your application.[/QUOTE]
Those seem to get pricey.
OP, search for cyberka's thread on it. He did it.
Gheybe is offline   Reply With Quote
Old 12-14-2011, 12:59 PM   #4
e.hilky
My Ride: 2004 330ci
Thanks for the response. I have been looking around lately. I'd like an LSD but for the price I think I might just look for a 3.64 diff and put it in. And do my cams. But my car is auto so I'm not sure what gears are in there now. I thought the autos had 2.93 not the 5spd. Am I wrong?
Old 12-14-2011, 12:59 PM   #5
blown330ci
My Ride: 330ci
Mine came with M3 lsd diff installed by previous owner so I don't know details other than anything's possible.
330ci, AA supercharger, bilstein suspension, M3 exhaust, 19' LM Reps
blown330ci is offline   Reply With Quote
Old 12-14-2011, 01:02 PM   #6
e.hilky
My Ride: 2004 330ci
Or is the auto 3.38. And would I notice a decent difference going from the 3.38 to the auto zhp diff which I think is a 3.64.
Old 12-14-2011, 01:03 PM   #7
Oliver.R
My Ride: 2000 328ci
http://forum.e46fanatics.com/showthread.php?t=595494
Oliver.R is offline   Reply With Quote
Old 12-14-2011, 01:53 PM   #8
TxZHP04
http://www.bokchoys.com/differential/GearRatios.htm
3.64 in an auto isn't quite so bad as the transmission is geared taller than in the manuals. Yes, you'd notice the difference between a 3.64 and your 3.38.
Old 12-14-2011, 06:42 PM   #9
e.hilky
My Ride: 2004 330ci
Very cool man. I was looking for something like that. Thanks.
Old 12-14-2011, 06:54 PM   #10
e.hilky
My Ride: 2004 330ci
I still believe for this year I'll do the cams. And 3.64 diff for now and see what that gets me. Then maybe next
Year the LSD. Or was thinking big brake upgrade. By first things first. Thanks again guys.
Old 12-14-2011, 07:54 PM   #11
Blocked Out
My Ride: Imola 330i M-Sport
I come back to see this.
I go.
Sent from my X10a using Bimmer App
Original BMW Teile ///
IMG_1725
Old 12-28-2011, 03:57 AM   #12
huskerick
My Ride: 325i/C6/928/951
3.91 rear out of an X3.
huskerick is offline   Reply With Quote
Old 12-28-2011, 04:00 AM   #13
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
Oh, damn, I didnt know the search feature was broken
/_________\
O==[][]==O
