Old 12-14-2011, 01:26 PM   #1
TiAg2247
My Ride: E39 M5 | E55 AMG
E39 540 6spd into E46 330?
Does this tranny bolt up just like the ZHP/M3 6spd transmissions? If not, what is needed? I have access to fantastic deal on a 540i 6spd with shifter/linkage/driveshaft (no clutch/FW though).
It'd be great if the above parts will just bolt up to my M54 and M3 diff.
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is online now   Reply With Quote
Old 12-14-2011, 09:26 PM   #2
Blocked Out
My Ride: Imola 330i M-Sport
Both cars(m3 and 540) use Getrag S6S 420G transmisions, both cars have identical gear ration.
In fact all of these cars mentioned below use this tranny
* 1996-1999 BMW E36 M3 (Euro)
* 2001-2006 BMW E46 M3
* 1988-1995 BMW E34 540i and M5
* 1996-2004 BMW E39 540i and M5
* 1995–2001 BMW E38 7 Series
* 1989–1999 BMW E31 8 series
* 2000–2003 BMW E52 Z8
But bellhousing bolt patters is OBVIOUSLY different.
Just look at both the pic of a M62 bolt pattern and an 50 series pattern (m52,54,s52,54) and you can clearly see that the pattern is different.
BASICALLY ,remember this. The trans are interchangeable between their series bothers ONLY.
M60, M62, S62 are all interchangeable
M50,M52,M54,S50,S52, S54 all all interchangeable
And such. A V8 trans wont ever line up to a 6cyl .
Original BMW Teile ///
IMG_1725
Old 12-14-2011, 10:22 PM   #3
TiAg2247
Very informative response. Thank you.
Too many mods
Past:
'04 E55 AMG
Old 12-14-2011, 11:16 PM   #4
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
can't you just swap the bellhousing from the tranny?
SL Blak Soldier is offline   Reply With Quote
Old 12-15-2011, 04:38 AM   #5
MSportBMW
My Ride: E46 325, EVO8 MR
Useful info I think to minimize hassle w/ tranny swaps...thanks
MSportBMW is offline   Reply With Quote
Old 12-16-2011, 08:14 PM   #6
Blocked Out
I would assume you can, but Im just guessing.
If you could, you would have to have 2 trans to begin with a (one from M3 and one from 540) and if you have both of them then why bother swapping anything when you can just stick the correct one in your car.
Even if its possible, noone on Earth would try it because it doesnt make any sense to do.
IMG_1725
Old 12-16-2011, 09:39 PM   #7
SL Blak Soldier
true.
hmmm maybe the 5spd bell housing has the same bolt pattern?
ps, because of the great info. add tags!
Old 12-18-2011, 08:01 PM   #8
Blocked Out
true.
Which tranny are you talking about? Which 5spd?
IMG_1725
Old 12-19-2011, 12:35 AM   #9
lab rat
My Ride: '02 330iT
true.
Good luck fitting the 6-speed gears into a 5-speed housing (the 6-speed is almost twice as big)
Because sleeper
Old 12-27-2011, 02:38 AM   #10
SL Blak Soldier
sorry, let me rephrase.
Separate the transmission from the bellhousing on the 6spd v8, and then do the same for the 5spd striaght6. then just swap the bell housing from the 5spd to the 6spd
well when you do 5spd to 6spd swaps you usually change the driveshaft as well.
540i, 6 speed, getrag s6s 420g, transmission
