Old 12-16-2011, 03:20 AM   #1
z_man93
My Ride: 328ci
p1397 Cause?
I've read all of the threads about "likely" scenarios which may lead to the lean condition error code, but does anyone know what causes the code to be reported? In the code of our ECUs there is a very specific event and threshold which results in p1397 being reported.
Example: with other engines there are known limits for O2 or MAP readings, which if exceeeded, would cause a similar code to be reported. Does anyone happen to know this trigger event for BMW?
Anthony Colin Bruce Chapman: Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
z_man93 is offline   Reply With Quote
Old 12-16-2011, 07:21 AM   #2
shanneba
My Ride: 2003 330Ci
Isn't P1397 a code for the exhaust cam sensor?
BMW Code P code
18 P1397
Exhaust cam Input analog Internal
check of phase shift from position sensor malfunction
phase shift (0-5V) camshaft sensor - should change during every crankshaft
revolution. Phase shift occurs due to 2:1 relationship between camshafts.
Join BMWCCA
Old 12-23-2011, 10:42 PM   #3
CrazyVWtunning
My Ride: VW Rabbit Pick up
have the same issue in a 2002 325 E46,,I replaced the sensor for an aftermarket one,,the code desapear for a while,,but I decided to drive the customer car home and after 15 minutes driving the light came back,,I was driving with my Autel Maxidas DS708 scanner when.the same code shows up,,is possinle that the aftermarket sensor is another issue ???
Sent from my LG-P999 using Bimmer
CrazyVWtunning is offline   Reply With Quote
Old 12-23-2011, 10:45 PM   #4
CrazyVWtunning
but my generic code was P0365,BMW Exhaust Positon Sensor signal
