Old 12-16-2011, 11:56 PM   #1
Jall
My Ride: 328Ci
Alternator compatibility
Hey guys,
I'm about to buy a new alternator for my 328Ci built 12/99 I'm just trying to figure out how interchangeable the E46 alternators are.
The part on my car is a 120A Bosch with a rectangle connector part number 12311432986 which I believe is the same part as 12-31-1-432-980-M14 on Pelican Parts.
As far as I can tell it's also the same as 12-31-7-501-599-M14 which is a couple of dollars cheaper.
Are the E46 alternators interchangeable (mounting holes etc.) as long as they have the same connector?
Cheers for any help.
Jall is offline   Reply With Quote
Old 12-17-2011, 08:17 AM   #2
mrshelley
My Ride: 2004 330i
Usually they are. I have a small 90 amp alternator on my 330 (it's lighter and smaller than the 330) from a Z3. It bolts right up but the only fitment difference between it and the 120 amp one is the pulley (different offset).
Old 12-17-2011, 11:56 AM   #3
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I believe the plug on the regulator is the only change for alts across the E46 models.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-16-2012, 10:12 PM   #4
fmzip
My Ride: '08 328xi / '01 530i
So did you just swap pulleys and it bolts right up?
fmzip is offline   Reply With Quote
