///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
#1 |
My Ride: '03 LSB M3 Vert SMG
Hey guys, never posted on the m3 section before but have been on e46 fanatics for a while.
Anyway, i have a problem. The smg doesn't stop priming (sound when unlocking or opening the car door) and makes a beeping sound as well, it's coming from the smg reservoir. (attached video showing the problem: ) Is it because my fluid is low? If so what fluid do I use? And what is the cause? Also the smg cog is yellow. Car is in neutral with handbrake on(shown on the attached pic) ![]() Car seems to drive fine with the cog on yellow, but haven't driven it since i've heard the smg continuous priming. For now, i've disconnected the battery. Hopefully you gurus on here can help me ASAP and any body in the future having this problem. Thank you so much in advanced.
![]() Last edited by Chewy; 12-18-2011 at 01:37 AM. |
#2 |
I *think* that the fluid for the SMG is Pentosin CH11s.
#3 |
If the pump is constantly activated then most probably your pressure accumulator tank is kaput also check for leaks on your clutch actuator.
Good luck.
330i SMG M-Sport Paket II Euro Spec
Mods: CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals, ![]() |
#4 |
i would let the car get cold and check the fluid it should be on max if it isnt add some, and see what happens. if that doesnt work take it to a mechanic let him do a bleeding i did it to mine and it worked fine.
#5 | |
Sent from my GT-I9100 using Bimmer
#6 |
Well I went to my trusted mechanic today and he ran the codes. He suspects it's the pump as it says that it's losing pressure or something.
Anyway rang up BMW and they said I can bring it in straight away but won't be ready for a while cause of Xmas, i thought may as well, so i did. I've dealt with a few service people at this Stealership before and they were useless and rude. Fortunately I got a good one today who was kind and helpful and also got me to talk to the mechanic who was also very nice. Hopefully all goes well! It's all under warranty. LUCKY! I'll keep you updated and hopefully this will help anyone else in the future.
#7 |
*UPDATE*
Got the car back from BMW yesterday. BMW said that they just replaced the salmon coloured relay and 'reprogrammed' the system. Car seems to work fine now. __________________
#8 | |
- danny
2006///M3Vert/AO8/Nappa/SMG/19's/HK/NoYokes/MatteGills&Grills
#9 |
Same happened to me!.. Sounded exactly the same as in your vid.. I replaced the salmon coloured relay.. Took it to a mates garage to clear the SMG fault code and been fine ever since :o)
E46 M3 COUPE SMG, TITANIUM SILVER
IMOLA RED LEATHER, NAV, HK SOUND PS2's on 19" WHEELS, ALI TRIM, SUN SCREEN BLUETOOTH, 55 PLATE ![]() |
#10 | |
I replaced the salmon colored relay, and it immediately fixed the problem! Oh, also, no "reprogramming of the system" was necessary. Sounds like a BMW excuse to add an aditional $300 of labor, since swapping a relay takes 5 seconds...stealership Last edited by abqm3; 10-03-2012 at 10:57 AM. |
#11 |
Nice bump. Glad to hear it worked out. Keep a spare salmon relay with you in the car!
![]() -2003 M3 Vert -1967 Mini Cooper |
