Old 01-04-2012, 03:21 AM   #61
MSportBMW
My Ride: E46 325, EVO8 MR
Rob with your planned set up I cant see how you would consider anything other than a custom tune for your car. The guy with the 323 who had the 272s fitted here in Sydney used a dyno shop that reflashed and custom tuned using the OEM ECU
MSportBMW is offline   Reply With Quote
Old 01-04-2012, 03:00 PM   #62
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I here you.
Don't get me wrong, I'll definitely get a custom tune if needed. BUT, I of course am going to
try to make it work the way it is with the Shark Injector. At this moment in time it's anyones guess, if it runs real good & makes good power after some manual fuel pressure tuning; well then I'll be done.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-04-2012, 03:04 PM   #63
LivesNearCostco
My Ride: 2003 ZHP 6MT
Rob, I'm not doubting your math at all. It does sound like you will need more gas than the stock injectors can deliver, at least at WOT. But doesn't someone here know whether the DME adjusts fuel mostly based on the MAF reading or mostly on the pre-cat O2 sensor (A/F ratio) reading?
I wonder.... if you only need that extra fuel at WOT, can the adjustable FPR be programmed to use a lower pressure most of the time and higher pressure only at WOT? Is it manually adjustable under the hood with a screw, or does it adjust dynamically based on intake manifold vacuum? Or will you have a "fun" button on the dash that raises the fuel pressure?
Speaking of which, don't our cars have the FPR built into the fuel filter? So do you set up the adjustable FPR inline with the existing one, or replace the existing one? Or is the stock FPR under the hood?
Originally Posted by Rob43 View Post
Currently I have a good deal of faith in two things, 1) My motor really will need more fuel. 2) The ability to dial down fuel pressure (if needed) manually, via an adjustable fuel pressure regulator.
Lets talk some very simple math.
I'm really hoping, crossing fingers and or praying that I don't need a custom tune.
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 01-05-2012, 01:08 AM   #64
Rob43
Rob43's Avatar
Originally Posted by LivesNearCostco View Post
Rob, I'm not doubting your math at all. I am. lol
It does sound like you will need more gas than the stock injectors can deliver, at least at WOT. Yes, I agree. But doesn't someone here know whether the DME adjusts fuel mostly based on the MAF reading or mostly on the pre-cat O2 sensor (A/F ratio) reading?
I wonder.... if you only need that extra fuel at WOT, I would think that based on the head & cams flowing more CFM compared to stock, it would need more fuel through the entire RPM band. can the adjustable FPR be programmed to use a lower pressure most of the time and higher pressure only at WOT? No. Is it manually adjustable under the hood with a screw, Yes. or does it adjust dynamically based on intake manifold vacuum? No. Or will you have a "fun" button on the dash that raises the fuel pressure? No.
Speaking of which, don't our cars have the FPR built into the fuel filter? Yes. So do you set up the adjustable FPR inline with the existing one, Maybe. or replace the existing one? Maybe Or is the stock FPR under the hood? No.
The stock E46 fuel pressure is 52 psi, if the stock FPR built into the fuel filter can be set higher than this, it may be left in place. If on the other hand it barely reaches that number, it will get replaced with a high performance non adjustable fuel filter. So I don't know yet what will be left in place, if some of the fuel system needs to be re-worked it will be. Below are the leading contenders for the FPR & gauge.
Aeromotive - Universal Compact Adjustable Fuel Pressure Regulator
http://store.vacmotorsports.com/aero...ator-p102.aspx
Aeromotive - Fuel Pressure Regulator / Gauge
http://store.vacmotorsports.com/aero...uge-p2062.aspx
Rob
Old 01-05-2012, 11:20 AM   #65
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
My local tuner was trying to get me to go with the AFPR route. He says he's had good luck with tuning. I wanted to get all my "modding" finished before a custom tune, though.
Old 01-05-2012, 02:28 PM   #66
Rob43
Rob43's Avatar
Santa Claus (wearing a brown jump suit / driving a brown truck) just delivered my Christmas gift to me.
A little eye candy...............UUC-TD-B1-E46-5-PO Twin Organic.
Twin Disk Flywheel/Clutch package
for E46 3-series 5-speed models
Street-friendly clutch performance
for extreme-power BMWs.
Twin Organic: 850hp, 640ft-lb applications
Rob
PS, my UUC Stage 2 LTW Flywheel & Performance Organic clutch kit may be available. 1,500 (Perfect) miles on it, # B1-A-PO Fits all 1999- 9/2003 production date E46 6-cylinder 3-series (5-speed models), Z3 2.5/3.0 with M54 engine, 1996-2003 E39 530i/528i/525i/523i.
ID:	431136   Click image for larger version
ID:	431137   Click image for larger version
ID:	431138   Click image for larger version
Old 01-05-2012, 07:51 PM   #67
Rob43
Rob43's Avatar
Brady,
You'll never be done "modding", it's some sort of sickness. I myself am on step 3 of a 12 step program to help my addiction, BUT IT'S NOT WORKING !
Old 01-05-2012, 08:18 PM   #68
WALKD U
My Ride: Just Fast!
Brady,
Rofl same here.
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-06-2012, 09:58 AM   #69
aggieE46
Keep it clean
aggieE46's Avatar
That setup is HOT!
No, I'll never be done... This I know.
Old 01-06-2012, 08:58 PM   #70
xixixi
Banned User
My Ride: 01 330x-xi
when/where do we meet? I'll be 25XX, 3.46, lwt flywhl, dinan long tube, ebay headers, massive wt red, tms ssk, tms pullies, sap/ccv/02 delete (many others)... when running juice 100 octane mixture Dyno numbers mean lil to nothing. I don't care win/lose/draw. I want to see what everyone is doing, VS what is/isn't working.
Old 01-08-2012, 10:21 AM   #71
DarkJoker
My Ride: 01 330ci
that clutch setup is amazing
DarkJoker is offline   Reply With Quote
Old 01-11-2012, 11:15 AM   #72
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
Originally Posted by Dirty Mike View Post
In before spdsktr tries to claim dominance.
ogm dood mi kar wil kik ur karz ass LOL
My car isn't fast. It WILL pull a half a car length on a stock ZHP, though (in a "controlled environment"). I'd like to get pulleys, but I'm done modding it. Time to save up for something better.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 01-11-2012, 12:12 PM   #73
Dirty Mike
My Ride: Fern Green 330ci
I was simply trying to get a rise out of you. :/
Dirty Mike is offline   Reply With Quote
Old 01-11-2012, 03:42 PM   #74
SPDSKTR
You'd like that too much.
Old 01-12-2012, 01:09 PM   #75
johnrando
My Ride: '06 330 CIC ZHP
Originally Posted by Iceman00 View Post
"Thank you for contacting us! Due to an influx of overwhelming demand we have started the development of the 2.5/2.8 boots. We are expecting the release sometime in the first quarter of next year. If you have a number of folks interested, we could arrange a group buy where as those on the list will be the first to receive the kits.
Sincerely,
Stett Performance"
I'll see for myself soon enough.
Any update on this?
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 01-13-2012, 12:56 AM   #76
Grande D
My Ride: E36 M3
Originally Posted by johnrando View Post
Any update on this?
Why do you want 2.5/2.8l boots? You have a 3.0
It will change your life!
Old 01-24-2012, 02:47 AM   #77
Rob43
Rob43's Avatar
So, I received a few new go-fast toys today !
All from forum sponsor Turner Motorsport:
1) Four new D-Force LTW5 / Lightweight Alloy Race Wheels - 17x9
Weighing in at 16.5 LBS each, as a reference; stock M68 wheels weigh about 22 LBS each.
2) Four BMW center caps.
3) Turner Motorsports Billet Adjustable Fuel Pressure Regulator.
Things are coming together,
Rob
Old 01-24-2012, 08:30 AM   #78
xixixi
Banned User
My Ride: 01 330x-xi
Rob
nice!
Old 01-24-2012, 09:10 AM   #79
hassmaschine
My Ride: '91 325ix
Rob
I'll tell you a little secret - S54 and M54 injectors are the same thing. The only difference is the S54 runs them at 5 bar and the M54 runs them at 3.5. you'd be far better off using your stock injectors and just increasing base pressure to get the fuel flow you need. there are other characteristics that change with injectors that are not desireable unless you can recalibrate everything. And it would still be better to recalibrate the tune for your new "real" fuel flow.
using 30# injectors with a tune meant for 24#, and using a FPR to adjust everything is not going to end well.. by the time you get the base pressure low enough for it to run, your fuel atomization will be pretty poor. you can't tune a modern DME using a FPR anyway, it's always going to be fighting you with adaptations.
no matter how badly people want it to be, adjusting base pressure with an AFPR is not tuning.
hassmaschine is offline   Reply With Quote
Old 01-24-2012, 10:02 AM   #80
aggieE46
Keep it clean
aggieE46's Avatar
Nice wheels! We'll be twinkies!
Rob
