Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#61 |
#62 | |
From the first post:
Then just follow the instructions on the first post. Once you press the NAVI button to go to the android side, you should see a screen that shows it's running the upgrade process, the Dynavin logo shouldn't show up at all. It should take about 10 minutes to complete.
![]() 2002 330 Cic Topaz Blue VMR 701; Front 19x8.5et35 225/35; Rear 19x9.5et45 245/30 | Spacers: 15mm front; 12mm rear | Megan Racing Coil Overs | Short shifter | eBay Strut Bar | Angel Eyes | LED Tails | Dynavin (Droid) | Vanos | DISA *My Car Thread (Pics & Mod details): http://forum.e46fanatics.com/showthread.php?t=873246 |
#63 |
I've given up the unit is gonna go back. All apps seem to fail downloading and I can't get the unit to install a new rom. The touch screen seems hard to scroll with also, I end up clicking a cell instead of scrolling. Very frustrating was really hoping this head unit was gonna rock.
#64 | |
![]() IR/IR 6 speed |
#65 | |
#66 | ||||||
~ SD ~ Similar issue here, the stock SD card (2gb) was working, I downloaded MapDroyd Maps to the device and then even updated to 2.2 with it. Cant confirm that it happened after the update. I go to download the Speech Synthesiser for Google Nav but kept getting a need more than (6 by memory)mb of storage. Ive been able to get the SD to work for a few seconds when mounting, then formatting, then not getting a response from MayDroyd saying that I dont have an SD card which was good but it appeared to fail on me again. It doesnt appear to last long. Also had a corrupt sd card notification, formatted but it still buggy. Anyone else having similar issues? Im about to try an old 1gb SD card and see how that goes. SolutionUpdate=== Played around with the sd card and eventually got it formatted on the android d99 unit and its working now with all SD cards, just have to be careful when mounting, unmounting. For me I will only mount while in the android side, in the sd settings menu where I can see the mount sd button, 1. Insert sd card 2. Tap Mount sd card For dismount I again only do so when in the sd card settings, 1.Tap unmount and wait a few seconds after confirmation of dismount. Do not put the left side sd in the right side sd of the unit, the card gets a "requires format/damaged sd card" once its back in the left side (nav) SD Card formatting Quote:
In other issues ~ USB ~ My 4GB USB seems to have been converted to FAT (64KB allocation size) and Ive been having everything from freezes/hangs to inability to error codes regarding not having sufficent privileges on my Windows 7 (Im an admin... which makes things interesting). Also it keeps saying it is write protected... I managed to put a few files on while plugged into the pc then all of a sudden it was write protected. Trying to format to FAT 32 defaults and its just not letting me, or at least it does but it just takes way to long to do and appears to freeze ~ Voice Input ~ -Has anyone had an issues or has been able to get their microphone to function on the android side of the d99. (Voice input a destination, Shazam a song, or make a memo etc) ~ Bluetooth ~ Has anyone else gone into their android side setting tried to turn bluetooth on, only to get no change aka switched off still aka Turn bluetooth on message still displayed. Also any app that requires bluetooth and it asks you to turn it on, when you go to do so, the unit freezes on me. Has anyone figured out how to trick bluetooth streamed music(radio side) into working on android side. Jeff has mentioned a push NAV and then mode to get it to work Quote:
~ Erase and go to Factory default ~ Ive already tried doing this and have not been able to actually go back to factory default for android, my apps are still there. "Solution" (Getting around it by reinstalling Android firmware) ~ Android side media ~ Quote:
I'm assuming that if you own an android mobile you can somehow connect to and stream your media across it?? 0.o? Anyone? ~SD CARD SIZE~ Anyone have any idea what the max size possible for the d99 unit is? Quote:
~Apps requiring an internet or data connection fail to work / .COM .NET ERRORS?~ Quote:
~ FREE OFFLINE TURN BY TURN VOICE NAVIGATION ~ I mentioned MapDroyd before which is a great offline worldwide map, but I need that voice nav. There is NavFree however you still need a data connection to search for addresses. Does anyone know anything thats available? Ive been looking around but nothing truly offline and free Might buy Sygic, Im glad they offer a trial because Id hate to buy an app only to find it doesnt bloody work on my android d99.However I have been able to get Google Maps Navigation to work "offline". Parked in my garage I got the directions to my destination, and drove away. It worked fine, however I did not have the voice synth installed (my sd issue leading to download issues) so cant confirm if that would work. Only downside is that when you go to close the app mid drive, it will cancel navigation and wont remember the route... bummer. Lots of things to discuss, hoping to provide as much as I can as I learn about this unit and android. Last edited by navman01; 02-09-2012 at 12:48 AM. Reason: More issues with the d99 unit... What the hell dynavin, terrible |
#67 | |
#68 |
I don't think the GPS Config file made a difference, but it doesn't hurt to have it.
The TimeZoneFixer and ClockSync definitely help get things going faster as long as you have an Internet connection already.
#69 |
can anyone do me a favor, and check their CPU speeds, with such as the AnTuTu CPU Master app. mine is ALWAYS at 500 mhz, no matter what i change the settings to. even when i set max at 250mhz, or max at 720 and min at 600, it always just stays at 500. im wondering if this could be related to my android music problems.
#70 |
Superscript keeps on freezing on me... anyone have any suggestions?
#71 |
Since dynavin uses the stock harness is there anyway to hook dice up to it and use it for satellite radio?
#72 |
Guys,
Those with a rooted and non rooted D99 platforms, could you please try the iBus application for Android we are making just to see if it works on those using the Dynavin CAN bus adapter. We have not touched this application in 2 months due to the lack of hardware availability, so I would appreciate if anyone could try this on. Also, once installed, could you please run a LS command (Those with a terminal emulator or else) under the /dev folder and send me the output back. iBus application for Android Password to unrar: xl8U>1C<.tM267E Many thanks in advance |
#73 | |
Is it possible to get your app to work with Resler IBUS adapter? http://www.reslers.de/IBUS/index.html
I still have one these laying from when I had my CarPC installed. It worked great I was able to control the Windows PC from the steering wheel and other data on the IBUS line. Im pretty sure Android can read the IBUS data if plugged in via USB. Let me know and ill try to test it. Quote:
#74 | |
HTH |
#75 | |
Lots of questions and problems in there but here goes on some of the issues: SD card size I have a 32GB Class 10 Samsung SD card running successfully. I am told it should go to 64GB but that is beyond my needs, so havent tried that. 2 GB SD Boot Card You have to remember that you must make the card "Active" just like a Harddisk partition before formatting. I use Easeus Partition Manager (free) for both - FAT16! USB formatting I am using an 8GB USB stick and have no issues. Never tried formatting (just quick format in Win7). Android Voice I may be wrong here, but I think it requires that you insert the external microphone in the back of the unit. Bluetooth You have to install an external bluetooth usb stick. I have a passive USB hub with a WiFi and a Bluetooth adapter. Both works (although WiFi is a bit flaky). Bluetooth connects the service connector for use with Torque Pro. An oddity is that Android will report "Paired but not connected" even if it is. Google Maps (Voice) If you start your journey while you have internet access you can disconnect and will get turn by turn direcetions all the way. I have google voice loaded and it works!!! Also off line. .com and .net errors In my oppinion the Android board in Dynavin has a very unreliable I/O. I have never experienced anything so flaky in my long life with IT (30+ years). Network connections bounce on and off, and many of the Android apps have issues with the communication (ie. Navigon). I don't think any other Android 2.2 unit in the market would survive with those stats. I hope this is being addressed in the next update of the FW.
Rover 75 CDTi (BMW pretender)
#76 | |
thanks |
#77 |
#78 | |
Marking a partition as active on a basic disk means that the computer will use the loader (an operating system tool) on that partition to start the operating system.
#79 |
#80 |
Woah, I've been kinda spacing out the last few weeks in relation to Dynavin stuff, does this mean that app + resler's v6 USB dongle = steering wheel controls mappable in android? (i.e. previous/next, home and back?)
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() |
