Old 02-29-2012, 09:11 PM   #41
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
up...is anybody with working heat/ac going to be in greenville next week? I'd like to hook up and see what your IHKA is reading vs mine.
-Chris
chris98891 is offline   Reply With Quote
Old 03-01-2012, 04:39 PM   #42
eastfreestyler
My Ride: E46, GC8, WRX
Subscribed on this thread.
I searched all over for solution for this "No heat problem"
Many people start the thread and doesn't update the final fix.
I have the same symptoms as you. I bought the car with the heat not working and I thought its just the thermostat (No overheat, No coolant leak, ET has no crack, fan blows good)
I replaced the thermostat and flushed everything with oem blue coolant but I'm still getting no heat.
I just bought new heater valve to see if that will work (which i doubt). I'll updated after I install them tomorrow
Btw, Dmax where in jersey are you located? I think I bleed the system correctly but it doesn't hurt to get local advise to do so (This is my first Bimmer, I've been on Subaru and honda game all my life)
eastfreestyler is offline   Reply With Quote
Old 04-20-2012, 08:26 AM   #43
Qwietstorm
My Ride: 330Ci
Send a message via AIM to Qwietstorm
Originally Posted by chris98891 View Post
so if I don't need to top off after this cycle, its probably not a bubble? also, does anybody have any ideas on testing the heater solenoid? it sounds like that could be my issue now, we feel it click but don't know if its stuck
Any update on this? Also OP, when your heat wasn't working were you getting an intermittent coolant light? I have the same issue and an intermittent coolant light.
-Joey
Qwietstorm is offline   Reply With Quote
Old 04-20-2012, 12:39 PM   #44
chris98891
My Ride: '16 X6 50i
It got hot again here in SC haha. I replaced the heater solenoid and that gave me some heat in half of the cabin sometimes. I'm not having the coolant light, however.
-Chris
Old 10-05-2012, 11:58 PM   #45
golanM3
My Ride: E46 M3
I now have the same issue in the wife's car, can you please share the fix to this problem? again, don't think it's FSR, already replaced water pump and t-stat, any other ideas?
golanM3 is offline   Reply With Quote
