Old 12-20-2011, 07:15 PM   #1
kerunt
My Ride: '06 ML350
What is this leak?
Just dove by my parking spot and noticed some shady-looking puddles! Something is leaking from the ZHP .
Looks like oil, but doesn't feel like oil. Ran my finger through it numerous times - not oily at all. Seems to be dripping near the rear axle.
Checked the oil, and it's above the minimum mark.
Any ideas?
Could this be the diff leaking?
'06 ML350
kerunt is offline   Reply With Quote
Old 12-20-2011, 07:18 PM   #2
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
ah the 'what is this leak problem...'
cant you go under the car and see?
Bemwe_03i is offline   Reply With Quote
Old 12-20-2011, 07:34 PM   #3
kerunt
My Ride: '06 ML350
I did have a look under my car and everything that I could see was dry. Interestingly enough, the lighter-coloured liquid seems to be spread over a good couple feet, perpendicular to the stall's direction; my parking doesn't vary that much... going to call up my mechanic right now and see if I can drop in for him to have a look.
'06 ML350
Old 12-23-2011, 09:35 AM   #4
kent330i
My Ride: 2005 330i ZHP
Send a message via AIM to kent330i
Could be Trans fluid, power steering fluid or the fluid inside the front control arm bushing.
kent330i is offline   Reply With Quote
