Old 12-23-2011, 04:40 AM   #1
mad328ci
My Ride: 2000 328ci
Post Weird Transmission Issue
hi fellas i own a 2000 328ci and just recently had the gearbox limp mode issue... the cog with exclamation mark warning comes on.... BUT this only happens when when i have the a/c on and the vehicle is on 'D' and stopped in traffic... i tried this over and over, with the a/c switched off nothing happens, the gear changes are all fine and even if i put it in steptronic manual mode from M1 it goes onto limp mode only if a/c is switched on... what are the possible things to look for?? i dont want to go to the dealerships as i just may have to sell my arm and leg....
mad328ci is offline   Reply With Quote
Old 12-23-2011, 04:42 AM   #2
mad328ci
My Ride: 2000 328ci
oh yes once the warning light comes on if i switch off the engine then restart it, the warning light disappears and car drives normal... there is no hesitation whatsoever so my hunch is some electronic issue rather than transmission going out...
Old 12-23-2011, 05:07 AM   #3
mad328ci
My Ride: 2000 328ci
is it worth mentioning that i do not have the original BMW battery in the car.... its been changed by the previous owner.....
Old 01-08-2012, 02:43 AM   #4
abnpx
My Ride: 328ci
You know I get this same problem in mine, it has happened whenever I switch the tiptronic but when I leave it running AUTO its perfectly fine. The time it did happen I just pulled over to a mall turned off the car for about 5 minutes then turned it back on and it was perfectly fine. Very weird but I will look into it soon.
abnpx is offline   Reply With Quote
